Creaking
zoo-BILLY-zoo
Hi,
there is a creaking noise coming from the front of my bike every time i ride i was just wondering if you guys had any idea what it could be it sounds like its coming from either, the headset or the front wheel.
All help is appreciated thanks
Billy
p.s Was formal 1-modd-1 but wanted fresh start (Y)
Edited by zoo-BILLY-zoo
Make sure you do up your headset BEFORE you do up your stem bolts, that way it will tighten properly, mine was creaking a while ago and I found that was the problem...
Also check your bar bolts are done up tight and evenly, especially if you have a three bolt bar clamp
Good luck, creaking grinding things are always annoying :angry:
Nathan (Y)
Nathan (Y)
