Profile Problems... The Cog Keeps Coming Loose
medwaytrials
Every cuple of days the lockring that holds the cog on my profile becomes loose. Everytime this happens i have to undo the bolts to fit the spanner in to tighten it back up which is a pain in the ass.
Im wondering if any of you people have this problem, if so, is there any way to stop it.
thanks chris
thanks chris
You might need a new lock ring. They only have a few alloy threads on them and are easily damaged. The lock rings are easy to get hold of try:
www.alansbmx.com
www.customriders.com
www.pijin.co.uk
They might not be on there web site but they have phone numbers so give them a call.
Paul
I had the same problem and ended up stripping the lockring when it came loose. This didnt strip the threads in the driver as they are stronger so i bought a new lockring, and threadlocked it in place, doing it up quite tight. Worked a charm (Y)
And I can add its still going strong now a fair few mounths down the line :).
Edited by samthebiker
could be a number of reasons, how old is the profile, has it just started happening or has it always happened? it could be something silly and easily fixed in which case buying a new lockring would be silly but it could be that the lockring is fooked and you need a new one lol, have a good look at it and make sure everything is fine
