Guest Posted January 19, 2006 Report Share Posted January 19, 2006 So I managed to hook the teeth on my rear 12t fixed cog I got a new 12t cog, and tomorrow im going to attempt to remove the old one. Looking on tartybikes they recommend that you do not use a chain whip to remove the cog as it can be very tight. This I understand after attempting to remove it with a g-clamp........It snapped shortly after beginning to turn.I have read on another thread, that one can clamp the cog in a vice, and turn the wheel but my concern with this is that surely im putting stress on the spokes and hub?? Is this something which is negligable and I can carry on and pull as hard as possible, or should I seek alternative removal methods?Im not going to the bike shop for this one. Quote Link to comment Share on other sites More sharing options...
ZeroMatt Posted January 19, 2006 Report Share Posted January 19, 2006 It is pretty dodgy but it worked for me, don't do it unless its the last resort, i clamped mine in between some pieces of wood so the teeth dug into them so it wouldnt slip. Quote Link to comment Share on other sites More sharing options...
dave85 Posted January 19, 2006 Report Share Posted January 19, 2006 There are no methods which dont involve large amounts of force on the spokes, but I don't know anyone who's knackered a wheel through this. Best way is wrap an old chain round it then stick a big pair of stillsons over the chain. Get someone else to hold the wheel and give the stillsons some pasty. Quote Link to comment Share on other sites More sharing options...
bee_ Posted January 19, 2006 Report Share Posted January 19, 2006 be a man, use your teeth! Quote Link to comment Share on other sites More sharing options...
smelly joe Posted January 19, 2006 Report Share Posted January 19, 2006 When i had to remove the 12 tooth cog on my onza, i heated the cog up with a blow torch and then put a rather large chain whip on and pulled it. it came off but took a lot of re-heating and pulling. Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 19, 2006 Report Share Posted January 19, 2006 Our local bike shop wiry-but-strong guy (every shop has one ) took mine off by wrapping a length of chain around the cog to protect it, then clamping it in a vice, and turning it ridiculously hard. Worked easily enough ('specially from my p.o.v., 'cos I didn't have to do shit). Quote Link to comment Share on other sites More sharing options...
Guest Posted January 20, 2006 Report Share Posted January 20, 2006 Well, all done now, I took an angle grinder to it, the idea about the wood or chain to prevent teethe from getting destroyed is most definately worth the time, I forgot to check this thread this morning when I went out, and didnt protect the old cog, as soon as they are in the vice they break off once any sort of pressure is applied.I tried it, along with two lecturer's and a technician from 'up the country' (i.e. big, burly, tank-like) and none of us could get it off turning the wheel, while we were turning, the spokes flexed alot, so much that i decided enough was enough.Brought in the angle grinder, ground down so i could just see the threads, got a hammer and a bar, and whacked the cog causing it to fracture, then it unscrewed by hand with minimal damage to the threads.I'll put up a picture once I get my phone back to show, im suprised there hasn't actually been more of these threads about, that was a proper pain in the arse. Quote Link to comment Share on other sites More sharing options...
