new_to_trials Posted January 19, 2006 Report Share Posted January 19, 2006 Hey just got some echo cranks form trials-uk but i ask dan ko to fit the acs freewheel that i order which he did very well nice of him but he put two spacers in it so the freewheel is touching the bb and as its grind and weld freewheel my freewheel tool does not work so really could you tell be how to get it off so i can take the spaces out.thankssam lewisIts does have two small hole on the freewheel were the naming goes do i need a tool to do that.sam Quote Link to comment Share on other sites More sharing options...
poopipe Posted January 19, 2006 Report Share Posted January 19, 2006 you're probably buggered then. I had to have mine cut off and it wasn't even welded. The two holes are for undoing the lockring but since you've had it welded you won't be able to do that.longer BB? Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted January 19, 2006 Report Share Posted January 19, 2006 Yeah poopie is right, a longer BB seems the only option Quote Link to comment Share on other sites More sharing options...
joewhite Posted January 19, 2006 Report Share Posted January 19, 2006 Hey i have the same problem, have you riden the bike yet? because if you have your screwed but if you havent do what i did=1. get a long nail. 2. put the nail in the hole 3. Hit it with a hammer in the direction to loosen itIt works if you havent wriden it because it isnt that tight but if you,ve riden it then you wont get it off very easyhope i helped joe Quote Link to comment Share on other sites More sharing options...
new_to_trials Posted January 19, 2006 Author Report Share Posted January 19, 2006 Hey i have the same problem, have you riden the bike yet? because if you have your screwed but if you havent do what i did=1. get a long nail. 2. put the nail in the hole 3. Hit it with a hammer in the direction to loosen itIt works if you havent wriden it because it isnt that tight but if you,ve riden it then you wont get it off very easyhope i helped joeThanks that worked for me great tip came off nice and easy and did not damage the freewheel but i do need a new bb 127.5mm one thanks for all the tips guys.sam Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted January 19, 2006 Report Share Posted January 19, 2006 Hey i have the same problem, have you riden the bike yet? because if you have your screwed but if you havent do what i did=1. get a long nail. 2. put the nail in the hole 3. Hit it with a hammer in the direction to loosen itIt works if you havent wriden it because it isnt that tight but if you,ve riden it then you wont get it off very easyhope i helped joeGood thinking that man promote him! Quote Link to comment Share on other sites More sharing options...
