Loctite
wardie
i went down to my local b&q to buy some loctite for my loose crankbolts but all i found was a wall full of products and i had no clue which one i needed, i asked an assistant who was pretty useless so i was wandering which one is the right one and also if i was looking in the correct shop.
sam
From Park Tool http://www.parktool.com/repair/readhowto.asp?id=58
* Loctite® 222- a low strength threadlocker (water bottle cage bolts, etc.)
* Loctite® 242- a low strenth threadlocker, but stronger than the 222 (good general use threadlocker)
* Loctite® 246- a medium strenth threadlocker
* Loctite® 290- a medium strength thread
* locker, with low viscosity wicking properties
* Loctite® 266 high strength threadlocker
* Loctite® 270 high strength threadlocker
* Loctite® RC603 retaining compound (for poor press fits)
* Loctite® RC609 retaining compound (for poor press fits)
* Loctite® RC680 retaining compound, high strength, large gap ability (for poor press fits)
so would that be a good one as it has medium strength and the last lot of threadlock that was on there ( dont know which one it was) did wear off quite quickly or is that normal
