ding_dong Posted January 17, 2006 Report Share Posted January 17, 2006 Hi I have rounded the head on my magura bolt, that fixes it to the frame so I can no longer romve the bolt, so what size extractor will i need to remove the bolt also what size drill bit will i need?One more question, where can I get them from? other than ebay, well if i need one smaller than 3mm becuase the smalest one on ebay is 3mm.cheers.Oh last thing how much sould i be paying for one or a set? I hope I won't need it more than once as I'm getting ti bolts.thanks. Quote Link to comment Share on other sites More sharing options...
Caleb Posted January 17, 2006 Report Share Posted January 17, 2006 I hope I won't need it more than once as I'm getting ti bolts.thanks. titanium bolts are shite !!they will cause many more problems than your std stainless steel ones believe me.total waste of money when you could get about 300 standard better bolts for the price of 4 shite ti ones Quote Link to comment Share on other sites More sharing options...
petit_pablo Posted January 17, 2006 Report Share Posted January 17, 2006 Use a small drill bit, 2mm or 3mm.Drill through the centre of the bolt then undo using pliers, mole grips or similar.Should work Quote Link to comment Share on other sites More sharing options...
dave33 Posted January 18, 2006 Report Share Posted January 18, 2006 you will have a hard job to drill them if they are stanless steel bolts, best thing cut them with a hacksaw blade where the champs join then you should be able to grab with molgrips Quote Link to comment Share on other sites More sharing options...
