Dougster Posted January 18, 2006 Report Share Posted January 18, 2006 Gav all the stoney lot better get some freebees to test out except chisholm he is a noob. Quote Link to comment Share on other sites More sharing options...
joshywa Posted January 18, 2006 Report Share Posted January 18, 2006 (edited) The arch needs to be moved up much higher on this one:Stevethanks if i add you to msn could you give me some help in the design of it e.g. stress points Edited January 18, 2006 by joshywa Quote Link to comment Share on other sites More sharing options...
Guest Posted January 18, 2006 Report Share Posted January 18, 2006 thanks if i add you to msn could you give me some help in the design of it e.g. stress points lol, do you know anything about product design? It's a good idea to do a bit of work yourself....If your having to ask about where stress is in a booster then im not so sure you should be designing one..... Quote Link to comment Share on other sites More sharing options...
joshywa Posted January 18, 2006 Report Share Posted January 18, 2006 lol, do you know anything about product design? It's a good idea to do a bit of work yourself....If your having to ask about where stress is in a booster then im not so sure you should be designing one.....fraid not mate i'm mearly looking for help not having a cheap stab at people... i designed the during a dt class and i'd be kinda researching by asking steve wouldn't ican i just ask what compeled you to have a go at me ??? is it ive annoyed you or you just want to have a go at a new member to make yourself feel big... if you cant say anything constructive dont post. Quote Link to comment Share on other sites More sharing options...
adamtrials Posted January 18, 2006 Report Share Posted January 18, 2006 thanks if i add you to msn could you give me some help in the design of it e.g. stress points He runs heatsink,Heatsink booster - £25ishYour booster - £5Hmm...However the heatsink boosters are amazingly ace Quote Link to comment Share on other sites More sharing options...
joshywa Posted January 18, 2006 Report Share Posted January 18, 2006 He runs heatsink,Heatsink booster - £25ishYour booster - £5Hmm...However the heatsink boosters are amazingly ace as i said mate "research" what better reasearch could there be than asking advice off a company Quote Link to comment Share on other sites More sharing options...
adamtrials Posted January 18, 2006 Report Share Posted January 18, 2006 as i said mate "research" what better reasearch could there be than asking advice off a companyYeah you posted at the same time as i did sorry.Ask a dt teacher for advice on stressy stuff?However if your dt teachers are anything like mine they are all d**ks thatcare more about drinking tea than helping... Quote Link to comment Share on other sites More sharing options...
Guest Posted January 18, 2006 Report Share Posted January 18, 2006 fraid not mate i'm mearly looking for help not having a cheap stab at people... i designed the during a dt class and i'd be kinda researching by asking steve wouldn't ican i just ask what compeled you to have a go at me ??? is it ive annoyed you or you just want to have a go at a new member to make yourself feel big... if you cant say anything constructive dont post.What im getting at is that your totally 'winging it' Here is some advice: Change the holes to slots, that way your booster will be universal for 'most' bikes.With regard to the distance between the top slot and the bottom of the curve (black dims)(see crappy paint shop edit) That distance can vary from bike to bike depending on the tyre and the rim.The olive colour is more like what it would look like, roughly, an the red is another area which you might need to consider because tyre width may result in rubbing at that point.What material are you going to use to make the booster out of? That has an effect on stress and such.Also, what CAD package are you using? Solidworks has stress analysis tools... Quote Link to comment Share on other sites More sharing options...
Caleb Posted January 18, 2006 Report Share Posted January 18, 2006 £3 seems waay to cheap to mee, it would take a good hour or two to do the program, then labour cost, and material.i think your best bet would be to just take him in a booster for him to get measurements off, a drawing would take a lot of time and effort if you didnt know what you were doing, including all the tolerances and radii and diameters etc. Quote Link to comment Share on other sites More sharing options...
joshywa Posted January 18, 2006 Report Share Posted January 18, 2006 (edited) What im getting at is that your totally 'winging it' Here is some advice: Change the holes to slots, that way your booster will be universal for 'most' bikes.With regard to the distance between the top slot and the bottom of the curve (black dims)(see crappy paint shop edit) That distance can vary from bike to bike depending on the tyre and the rim.The olive colour is more like what it would look like, roughly, an the red is another area which you might need to consider because tyre width may result in rubbing at that point.What material are you going to use to make the booster out of? That has an effect on stress and such.Also, what CAD package are you using? Solidworks has stress analysis tools...i'm using pro desktopthe slot are going to be added just (as i said some where) i knoked this up quickly£3 is the cost to have them machinednot sure what its to be made from ive only spoke to the guy (monkey gav) oncethanks for the help... quick question where could i get solid works (on the net) or do i need to spend £300 in a shop ??? Edited January 18, 2006 by joshywa Quote Link to comment Share on other sites More sharing options...
Guest Posted January 18, 2006 Report Share Posted January 18, 2006 i'm using pro desktopthe slot are going to be added just (as i said some where) i knoked this up quickly£3 is the cost to have them machinednot sure what its to be made from ive only spoke to the guy (monkey gav) oncethanks for the help... quick question where could i get solid works (on the net) or do i need to spend £300 in a shop ???I got it off emule, its an overnight download really weighing in at 1.5gb'sIt didnt come with a serial number of registration but I didn't have trouble finding them on line.Where can I get pro desktop? I used it at school 4 years ago and I want to see if its much better than solidworks.....Also, the best way of doing it, and I think steve from heatsink has done this too, is to make yourself a wee design out of cardboard, stick it on the bike where the bolts are, and see if it clears everything, if it doesnt, you'll need to cut away the bit that rubs... Quote Link to comment Share on other sites More sharing options...
joshywa Posted January 18, 2006 Report Share Posted January 18, 2006 I got it off emule, its an overnight download really weighing in at 1.5gb'sIt didnt come with a serial number of registration but I didn't have trouble finding them on line.Where can I get pro desktop? I used it at school 4 years ago and I want to see if its much better than solidworks.....Also, the best way of doing it, and I think steve from heatsink has done this too, is to make yourself a wee design out of cardboard, stick it on the bike where the bolts are, and see if it clears everything, if it doesnt, you'll need to cut away the bit that rubs...if you want it i'll add you to msn (dont think you want to give away an address on tf) and i can can send you a copy on cd.... Quote Link to comment Share on other sites More sharing options...
B.E.A.U Posted January 18, 2006 Report Share Posted January 18, 2006 hay mate. erm i may be interested in one of the boosters. could you add me to msn beau_forrest89@hotmail.com and can he anodise other things? Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted January 18, 2006 Report Share Posted January 18, 2006 Well for starters it definatly has to be 4 bolt.I would also like it to be similar to the echo control brake booster with alot more tyre clearance, because i cannot run my control booster because there is not enough tyre clearence. yeh if its to my taste i will take one off you for 5 posted defo. ( anodised green - like the new zoo bars colour).Dan ! Quote Link to comment Share on other sites More sharing options...
tank_rider Posted January 19, 2006 Report Share Posted January 19, 2006 For a start you can't just copy a design, or even just make a couple of tiny changes.Secondly, unless you know what your doing with stressess etc, then please leave the boosters to the experts. It's easy to make a stiff booster, its another thing to make one that is a reasonable weight with it. I know Steve isn't making a fortune from each booster he sells, the majority of the price (something around 75% probably) is made up by the manufacturing costs. I know for a fact that of all the boosters I've used or seen, Steve's are the best quality, both in tems of design and manufacturing. Also if you're going to be setting up in competition with Steve, I highly doubt he is going to give you a hand in designing a product, that just wouldn't be good business!! Oh and depending on what degree your d&t teacher did, he may not have any more knowledge on the subject of stresses than you do!It looks like your after making a quick buck, but without caring about how you do it or what your customers get, please please please stop right now before you give yourself a bad name and annoy people. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 19, 2006 Report Share Posted January 19, 2006 For a start you can't just copy a design, or even just make a couple of tiny changes.Secondly, unless you know what your doing with stressess etc, then please leave the boosters to the experts. It's easy to make a stiff booster, its another thing to make one that is a reasonable weight with it. I know Steve isn't making a fortune from each booster he sells, the majority of the price (something around 75% probably) is made up by the manufacturing costs. I know for a fact that of all the boosters I've used or seen, Steve's are the best quality, both in tems of design and manufacturing. Also if you're going to be setting up in competition with Steve, I highly doubt he is going to give you a hand in designing a product, that just wouldn't be good business!! Oh and depending on what degree your d&t teacher did, he may not have any more knowledge on the subject of stresses than you do!It looks like your after making a quick buck, but without caring about how you do it or what your customers get, please please please stop right now before you give yourself a bad name and annoy people.That's how I would have put it had I known better. Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 19, 2006 Report Share Posted January 19, 2006 Hold up one sec....£3 to machine it£__ for materials£__ for postage£2? for anodising it£__ for markup +£______full priceSo it wouldn't really end up being anywhere near £3 at all? Quote Link to comment Share on other sites More sharing options...
OD404 Posted January 19, 2006 Report Share Posted January 19, 2006 Also, what CAD package are you using? Solidworks has stress analysis tools...I'd be a little wary of the results you get from the built in stress analysis tool in Solidworks. From my experience it has been optimised for speed as opposed to accuracy which will lead to errors within the results. Also, because you are unable to edit the size of the mesh used in the analysis, there is no way to improve the accuracy.For anyone serious about doing stress analysis with Solidworks, I suggest you look into obtaining a copy of ComosWorks, which will provide greater control and accuracy.But don't forget, all these programs by their vary nature, carry some level of inaccuracy.In terms of the designing a booster, there have been numberous posts in the past in which the ideal shape of a booster has been discussed, a quick search should yield some good information. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 19, 2006 Report Share Posted January 19, 2006 I'd be a little wary of the results you get from the built in stress analysis tool in Solidworks. From my experience it has been optimised for speed as opposed to accuracy which will lead to errors within the results. Also, because you are unable to edit the size of the mesh used in the analysis, there is no way to improve the accuracy.For anyone serious about doing stress analysis with Solidworks, I suggest you look into obtaining a copy of ComosWorks, which will provide greater control and accuracy.But don't forget, all these programs by their vary nature, carry some level of inaccuracy.In terms of the designing a booster, there have been numberous posts in the past in which the ideal shape of a booster has been discussed, a quick search should yield some good information.Yep, that's what we have in college and im using at the minute, just couldn't remember the proper name for it as I havn't got it installed at home. Quote Link to comment Share on other sites More sharing options...
joshywa Posted January 20, 2006 Report Share Posted January 20, 2006 some revised design'shope you like Quote Link to comment Share on other sites More sharing options...
dave85 Posted January 20, 2006 Report Share Posted January 20, 2006 My sister could do a better job Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted January 20, 2006 Report Share Posted January 20, 2006 The arch is still wayyyy to low, do some measuring!I don't have a problem whith this guy making his own boosters, as long as he doesnt just copy someone elses design, but even if they are cheap, they wont be as good as some others, you get what you pay for! and as mark said, there likely to be a lot more than £3, materials are likely to be almost £3 per piece, depending what grade alloy your using. Quote Link to comment Share on other sites More sharing options...
mat hudson Posted January 20, 2006 Report Share Posted January 20, 2006 move the arch up and make it so its an "I" beam rather than an "L" beam. Quote Link to comment Share on other sites More sharing options...
OD404 Posted January 20, 2006 Report Share Posted January 20, 2006 My sister could do a better jobBut if your sister is anything like you, she could probably do it better than me I'd revise the thickness of your design, if it is to be made from aluminium I'd say it has nowhere near enough material in the right places for it to be effective.As for the cross section, an I-beam would be better in theory as material will be placed at the area subjected to higher stresses. However the cross-section design that has been put forward (probobly un-beknown it its creator) is not that bad either. Materials such as aluminium and steel work better in compression than tension (in theory), therefore the reinforcent requirements for the top edge are less than those on the bottom edge (top edge will be in compression due to bending, bottom will be in tension).A picture can tell a thousand words, but dimensions would tell us so much more... Quote Link to comment Share on other sites More sharing options...
Bored Posted January 20, 2006 Report Share Posted January 20, 2006 once again gav ur tryen to make mony !! its good idea this time though!!try cad as u said ur a wizkid on it make it simple and well get em made u want one if ur able to but if no i aint haven one of ur hand cut jobs!!! cheerschiz Christ, Did you go to school?Go for the booster thing mate, me and a mate from school make some sometimes! K Quote Link to comment Share on other sites More sharing options...
