Nose In's
rickyb
Hay,
The problem I have is that I would like to learn nose in's but I dont have the right techneque(sp :- ) and when I try to learn them from my mates it dosen't seam as easy as it looks. When I got to gap to front wheel I bottel it and end up roling onto what ever it is I'm practising on. Is there anyway you learnt that would be easy like practise one move then move onto the nose in's? cheers for any help :)
rickyb
Edited by rickyb
Hi try geting two crates and doing the gap to front wheel as far as your comftorbale with and then when you can do it keep miving the two crates further away from each over (Y) but what ever u do stay 110 percent comitted and say to yourself come on i can do this (Y)
When I started, I would put my front wheel up on a curb or pallet and practiced lifting up my rear wheel and rolling on, really exaggerating the rear wheel lift until I could do a front/rear wheel switch on the edge of the curb. This just helped with body postion, I found my body weight had to be quite far over my bars.
Once you start gapping to front wheel, keep your arms locked when your front wheel first lands on the object and really bend your knees to pull your rear wheel up. Be careful, you don't want to catch your front wheel on the object and go over the bars.
Dallas
