Rear Wheel Help
Ben Collins
This morning my 19" rear echo wheel arrived. I also got a 12t cog with it my problems are:
  1. Should i force the 12t cog on as it seems pretty hard even though i am sure that im not crossthreading it.
  2. It came with snail cams which i have never used before, and i here you need a bolt or something to put into the frame to make the snail cams work, if so i need to buy some and where can i get them?.
Thanks alot Ben
