Euro Braker Posted January 14, 2006 Report Share Posted January 14, 2006 my ACS CLAWS freewheel has started grating. would i be able to open it to grease it or is there other ways.it started when i was cleaning my wheel and started puttin it on my bike and when i put the chain on it started grating.PLEASE HELP!!! Quote Link to comment Share on other sites More sharing options...
Dallas Posted January 14, 2006 Report Share Posted January 14, 2006 What do you mean by grating? My friend uses one and he would always unthread the back and check the ball bearings. Often the ball bearings would fall out of place. Thread the face plate back on and he was good to go.Dallas Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted January 14, 2006 Report Share Posted January 14, 2006 What do you mean by grating? My friend uses one and he would always unthread the back and check the ball bearings. Often the ball bearings would fall out of place. Thread the face plate back on and he was good to go.Dallasthe bearings shouldnt fall out of place if the freewheel was tight, and if he still had them 3 thin washers inside to keep them in order...Look in my siggy and learn away (grease first though ) Quote Link to comment Share on other sites More sharing options...
Euro Braker Posted January 14, 2006 Author Report Share Posted January 14, 2006 i dont actually no how to open it and i hav never seen the inside of one it sounds like sand has got inside and is grinding at the barings Quote Link to comment Share on other sites More sharing options...
wardie Posted January 14, 2006 Report Share Posted January 14, 2006 i think i may have the same problem as you, does it do it when your crank is in a certain position when your riding.also do the insides of an acs claw freewheel have bearings all the way around the inside bit or mite a couple of mine fallen out as my lockring was loose.sam Quote Link to comment Share on other sites More sharing options...
Euro Braker Posted January 14, 2006 Author Report Share Posted January 14, 2006 i have put the wheel on the frame and when i put tension on the crank it cracks and grinds. when i ride it it sounds like the barings are loose and are rolling/grinding insideby the way my lockring isnt loose Quote Link to comment Share on other sites More sharing options...
wilky_mod_legend2 Posted January 14, 2006 Report Share Posted January 14, 2006 I had this problem ages ago, i thought it was my bearings,but check that the tabs on the acs are not rubbing on b/b shell. This happended to me even when i was running 127.5 b/b. Pulling apart freewheels is a pain to be honest, ACS arent pricey, might be worth just gettin a new one, or go PROFILE click click lol.cheers wilky Quote Link to comment Share on other sites More sharing options...
aff1e Posted January 14, 2006 Report Share Posted January 14, 2006 squairt some de greaser in it to clean it out and then squirt some WD40 in it and it should work fine it happened to me, or if it isnt much you could be missing some bearings or da back is loose hope i helped tom Quote Link to comment Share on other sites More sharing options...
Euro Braker Posted January 14, 2006 Author Report Share Posted January 14, 2006 thanks 4 ur help. i tried it and still sounds the same. the freewheel is on the rear so it isnt rubbing but when it clicks it is when the links of the chain is coming off the teeth.i hav cleaned/oiled the chain and it carrys on. Quote Link to comment Share on other sites More sharing options...
watto Posted January 14, 2006 Report Share Posted January 14, 2006 best thing you could do is get a new chain freewheel and cog Quote Link to comment Share on other sites More sharing options...
