Magura 05
weebryan
Can you buy the hs33 05 lever blade on its own any were with the adjuster barrel, the adjuster has seized and i have repaired it a few times with tap and dyes but it keeps happening, they should use a steel one insted of plastic which is not strong enough threads on it .
Edited by weebryan
