Bluegrass Posted January 12, 2006 Report Share Posted January 12, 2006 So i replace my brake light bulbs as they both were shot, but still theres no hope. Im guessing there must be internal wiring problems, so its a garage job. Would anyone know what the basic problem would be, and costs of wiring for brake lights? Maybe a long shot but just need a clue, cheers Quote Link to comment Share on other sites More sharing options...
deagledaddy Posted January 12, 2006 Report Share Posted January 12, 2006 Fuse blown..... harldy any cost damp in the wiring.... hard to diagnoe, unlikely to be mega bucks probably loads of otehr things too. Fuse would be top of my list though Quote Link to comment Share on other sites More sharing options...
JTM Posted January 12, 2006 Report Share Posted January 12, 2006 ill second fuse lolIf both bulbs are out, its usually a beter first bet than changing bulbs! Quote Link to comment Share on other sites More sharing options...
haydon_peter Posted January 12, 2006 Report Share Posted January 12, 2006 I would hope there was more than one fuse for the brake lights? I read somewhere about someone getting pulled by the police on a motorway at night because they had no rear lights, it turned out both the left and right rear lights were on the same fuse So it would be a bit stupid if it was just one fuse for both rear brake lights... Quote Link to comment Share on other sites More sharing options...
Danny Posted January 12, 2006 Report Share Posted January 12, 2006 So it would be a bit stupid if it was just one fuse for both rear brake lights...Its quite possible as fuses go rather rarely and if they do its usually for a reason.E.g. on a mini a single fuse does all the followingstoplights, reversing lights, indicator flasher unit, heated rear window Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 12, 2006 Report Share Posted January 12, 2006 Sure its not your brake switches? Quote Link to comment Share on other sites More sharing options...
endofreak Posted January 13, 2006 Report Share Posted January 13, 2006 I've never come across a car that has had more than one fuse for the brake lights. Quote Link to comment Share on other sites More sharing options...
trials_pimp Posted January 13, 2006 Report Share Posted January 13, 2006 I would hope there was more than one fuse for the brake lights? Your hopes fade.There usually is only 1 fuse to contol the brake lights, and its usually paired with a few other systems.Bluegrass, what car do you have?Instead of taking to a garage, fix it yourself. Brake lights are a very simple circuit on most cars (all but the newest computer controled cars)Youve got the brake light switch on the pedal, fuse, bulbs, wiring, and power and earth.check you have 12v coming to the switch, and 12v coming to the bulb holder when the pedal is down (good tip here, use a long screwdriver/stick to wedge against the seat and hold the pedal down while toy check for feeds)Check that the bulb holder hasnt corroded away (comon on alot of cars) and that the earth is good.Easily done, with very little tools. Quote Link to comment Share on other sites More sharing options...
