rickyb Posted January 12, 2006 Report Share Posted January 12, 2006 (edited) Hay, the problem is i have instaled a wireless conection on my comp got it all working and when i log off my comp it f**ks up again it comes up no default gateway so i need to re-install it like the Bt guy told me too.I'm sure there is a way that i can save my settings but i'm not sure how to do it could any of you guys help?Any help would be great cheers rickyb Edited January 12, 2006 by rickyb Quote Link to comment Share on other sites More sharing options...
poopipe Posted January 12, 2006 Report Share Posted January 12, 2006 Hay, the problem is i have instaled a wireless conection on my comp got it all working and when i log off my comp it f**ks up again it cmes up no default gateway so i need to re-install it like the bt guy told me too.I'm sure there is a way that i can save my settings but i'm not surebhow to do it could any of you guys help?any help would be great cheers rickybget it working againopen a command prompt type ipconfig /allpress enter.lots of complicated looking numbers should appear. put the numbers that match (ip address, subnet mask, default gateway. You might as well do the DNS as well) into your wireless connections TCP/IP settings. right click on the connection > properties > pick Internet Protocol(TCP/IP) > click properties > put the numbers in the matching holes > click OKthat'll save everything. Quote Link to comment Share on other sites More sharing options...
rickyb Posted January 12, 2006 Author Report Share Posted January 12, 2006 (edited) It comes up with default gateway and nothing next to it rickybedit: cheers mate sorted it now:D thansk a lot dude Edited January 12, 2006 by rickyb Quote Link to comment Share on other sites More sharing options...
mike Posted January 12, 2006 Report Share Posted January 12, 2006 Try resetting the router / modem, and if you can, i'd probably run a cbale under tha carpet or something, it's a lot more reliable, and you'll have much fewer problemd, although once the router is set up, you should be fine.Mike!!! Quote Link to comment Share on other sites More sharing options...
