Renault Megane Coupé
The enchanted broomstick
So i have absolutely huuuuuge interference levels coming through my stereo, its not through the front speakers which are running solely from the headunit its from the rear speakers and sub.
I know about not having the RCA (phono cable) right next to the power cable so i have the RCA cable running down the right hand side of the car (sitting in drivers position) and the power cable running down the left hand side of the car. I have added an interference surpressor to the power supply going to the headunit but still get major interference levels and its really bugging the hell out of me.
any ideas?
Also anybody ever had problems with a renault car revving itself? I mean like "hunting/searching" as people call it on idle or when i put the clutch right in.
stu (Y)
What RCA cables do you have? I'm guessing cheapy ones? By the sounds of it, they don't have sufficent sheilding. Try some better shelided cables. You want to spend at least £10 on a set of RCA leads.
As for the rev hunting...you need to find the stepper motor (can also be known as an idle control valve, as well as many other things, but they all mean the same thing)
Anyway, this needs cleaning with something like brake cleaner, WD-40, GT-85, or something like that, basically you want to shift the crap out of it.
I can't tell you exactly where it is on the Megane engine, but seeing as both our cars are French (and seeing as its the logical place to put it) it will be somewhere near throttle body. All it is, is a little motor that controls how much the throttle is held open at idle speeds. On my 306 engine, it is held on by 2 allen screws.
An easy way to find it will be to look at the throttle housing, and there will be some kind of electrical plug. If you pull this plug, the engine will start revving higher and higher. Once you find this plug, you have the stepper motor (Y)
Hope that's some kind of help to you
Got a ground loop isolator ordered for collection tomorrow morning, will let you know how i get on i asked a few peoples opinions and they reckon it's the best option so im going for that. Thanks UrbanLegend! George, im gonna have a look at that idle valve thingy mcjiggy. I've found a guide on the net of how to completely remove and clean it all etc. Sounds like fun to me - so if my car no longer works after this, im holding you solely responsible :-
cheers, stu (Y)
