Mitch A Posted January 11, 2006 Report Share Posted January 11, 2006 Hey,I was leaving to go riding earlier and i found my dad had accidently sprayed WD40 on my disc rotor.It does not grip no where near like it used to. How can i make it better again as in what shall i use to sort it out or replace bits.Its a Hope Mono Trial 160 mm if that helps at all.Cheers for the helpMitch Quote Link to comment Share on other sites More sharing options...
ogre Posted January 11, 2006 Report Share Posted January 11, 2006 takr the disk off the hub, put it in the dishwasher! and take the pads out, and sand paper them so there not WD40d no more! (the dishwasher thing KICKS ASS) Quote Link to comment Share on other sites More sharing options...
Mitch A Posted January 11, 2006 Author Report Share Posted January 11, 2006 Cheers mate, Dishwasher Anybody else got any ideas? Quote Link to comment Share on other sites More sharing options...
T-BAD Posted January 11, 2006 Report Share Posted January 11, 2006 you could boil the disc.... i have'nt done it yet but it is supposed to work. you could also bake or boil the pads too, or poor something flamable on it then burn them more fun Quote Link to comment Share on other sites More sharing options...
JIX Posted January 11, 2006 Report Share Posted January 11, 2006 No need to remove it. Just hose it down, then clean with warm soapy water, then hose down thoroughly, dont leave any residue.Then take the pads out and get a blow torch, and flame them for a while. Not to long, but you will see when yoou do it, they burn like little red bits, and when it is done there arent any left, if you understand me.You can do a search on the subject too Quote Link to comment Share on other sites More sharing options...
poopipe Posted January 11, 2006 Report Share Posted January 11, 2006 are there any not hot alternatives ? i thought maybe alcohol or detergents .. Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted January 11, 2006 Report Share Posted January 11, 2006 Muc-off Quote Link to comment Share on other sites More sharing options...
MrSuave Posted January 11, 2006 Report Share Posted January 11, 2006 Disc brake cleaner........ DUH! degrease's and evaporates...... bye bye WD40 Quote Link to comment Share on other sites More sharing options...
JT! Posted January 11, 2006 Report Share Posted January 11, 2006 Wouldn't boiling the pads melt the glue that holds them on? Quote Link to comment Share on other sites More sharing options...
steve sturt Posted January 11, 2006 Report Share Posted January 11, 2006 Wouldn't boiling the pads melt the glue that holds them on? Erm.......................................NoThey use a special adhesive that would probaly hold the wings on a jumbo jet. Discs can get very hot. And yes the wings on a lot of a planes are glued on. Quote Link to comment Share on other sites More sharing options...
wolfie Posted January 12, 2006 Report Share Posted January 12, 2006 I’d say the same as JIX. Clean the rotor with some warm water and washing up liquid and burn the WD40 off the pads with a blow torch. If you don’t have a blow torch just replace the pads and clean the rotor as already mentioned. Wolfie Quote Link to comment Share on other sites More sharing options...
Synergy Posted January 12, 2006 Report Share Posted January 12, 2006 (edited) my dad poured aviation fuel on my one (aeroplane fuel) then light it BURN BABY BURN Edited January 12, 2006 by Synergy Quote Link to comment Share on other sites More sharing options...
Technical Tom Posted January 12, 2006 Report Share Posted January 12, 2006 Just boil both your pads and rotor, then whilst they are in the water get a clean scrubbing brush and scrubb hard and then just bed it in again as usuall. I've done this many times so it does work Tom. Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted January 12, 2006 Report Share Posted January 12, 2006 Best thing we use for cleaning brake componets is thinners, ittotally degrease's & then evaporates to dry on its own. But make sure you do it outside or it will be, Quote Link to comment Share on other sites More sharing options...
scott-mad Posted January 12, 2006 Report Share Posted January 12, 2006 i just stick my rotor in washing up bowl and take pads of and rub them on a flat bit of wet and dry. that works just as well then put back together and then pour water over the caliper and rotor ride as fast as you can and slam the break on. then do it again but just dab it on and off till it dries due to heat and should work dandy Quote Link to comment Share on other sites More sharing options...
nb88 Posted January 12, 2006 Report Share Posted January 12, 2006 Wouldn't boiling the pads melt the glue that holds them on? It melted the glue when i did it to my hope mini pads Quote Link to comment Share on other sites More sharing options...
JT! Posted January 13, 2006 Report Share Posted January 13, 2006 (edited) Erm.......................................NoIt melted the glue when i did it to my hope mini pads So is it safe or not. Edited January 13, 2006 by JT! Quote Link to comment Share on other sites More sharing options...
JIX Posted January 13, 2006 Report Share Posted January 13, 2006 Sanding your pads doesnt help at all because disk pads absorb the fluid!!!Burn or boil them, I burnt my ones and they are fine. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted January 13, 2006 Report Share Posted January 13, 2006 Mine was like this up until two days ago when i sorted iot out. Here's basically what i did to it and it has made it absolutely awesome.Take your wheel out and then take the brake pads out of the disc brake.Take the pads into the kitchen and turn on one of the gas rings on the hob. Hold the pads with pliers or something else that will result in your hand not getting burnt, and hold them in the flames after a while they will start to smoke and you will most likely see little sparkles of bright light burn from them. I burnt mine for approxiamtely 2 minutes. Do this for both the pads.Get hold of a saucepan and fill it with water. Then put that on the gas ring and let the water get hot. Drop the pads in and leave them in there to boil, mine were in there for around 20 minutes to make sure it worked.At the same time as the pads are boiling you can bring your wheel in (you can use wire wool as well just to take the majority of the crap off the rotor but this is optional) and put some washing up liquid on a clean or preferrably a brand new cloth or sponge. Just put a little washing up liquid on it and rub it in to make sure you won't have too much washing up liquid on there, just a slight bubbly mix ias all you need.Proceed to clean off the disc rotor with the washing up liquid and then get a clean dry cloth to dry off the excess moisture when its been thoroughly cleaned. At this point your pads should be about done.Take the saucepan off the gas ring and pour the hot water into the sink. then pour some cold water into the saucepan just to cool tha pads off a bit so you will be able to hold them.Wipe the surface of the brake pads on a clean dry cloth, i used a teatowel but do so at your own risk of raging mother syndrome. You should find theres a load of black muck thats smeared onto the cloth at first, but after a good rubbing this black brake crap will be pretty much gone and you pads will now be ready for putting back on the bike.Re-attach the neccessary parts and bed the brake in as normal. Just hold the brake slightly as you ride around (not so it locks up) and when it starts to get noticeable more grippy pour some cold water on it, you should get a load of hissing and steam from it if you got it hot enough. Then ride around with the brake slightly omn again to clear the water off and wait for it to cool down again.That should be it then, you'll have a nice working front disc brake!have fun Quote Link to comment Share on other sites More sharing options...
benno Posted January 13, 2006 Report Share Posted January 13, 2006 Good post! Quote Link to comment Share on other sites More sharing options...
DeeZee Posted January 13, 2006 Report Share Posted January 13, 2006 Jesus Wept.... are you all mental.... I hope none of you every have a leaking brake caliper on your car. I can see you all trying to squeeze the fooking whole front wishbone suspension and disc into a bowl of water in your kitchen, while screaming..."No, No, Its alright mum, it works, I read it on the internet"If you have WD40 on your rotor, just use a degreasing agent, maybe thinners, Christ, even vinegar would also work. You don't need to boil the thing.... its the stupidest idea I have ever heard, a pure exercise is wasting time Boiling it won't displace WD40.... WD... Water Displacer ... Water can't displace it... ring any bells. Washing up liquid has degreassing properties, but its also soapy, and leaves a fine film, unless thoroughly rinsed.Again boiling pads won't remove any WD40 from them if its penatrated the compound, your not going to coax it out with water. The pads will pretty much be a write off. Using regular unleaded petrol on a cloth would help to considerably clean the surface, but again.... if its penatrated. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted January 13, 2006 Report Share Posted January 13, 2006 Jesus Wept.... are you all mental.... I hope none of you every have a leaking brake caliper on your car. I can see you all trying to squeeze the fooking whole front wishbone suspension and disc into a bowl of water in your kitchen, while screaming..."No, No, Its alright mum, it works, I read it on the internet"If you have WD40 on your rotor, just use a degreasing agent, maybe thinners, Christ, even vinegar would also work. You don't need to boil the thing.... its the stupidest idea I have ever heard, a pure exercise is wasting time Boiling it won't displace WD40.... WD... Water Displacer ... Water can't displace it... ring any bells. Washing up liquid has degreassing properties, but its also soapy, and leaves a fine film, unless thoroughly rinsed.Again boiling pads won't remove any WD40 from them if its penatrated the compound, your not going to coax it out with water. The pads will pretty much be a write off. Using regular unleaded petrol on a cloth would help to considerably clean the surface, but again.... if its penatrated.Thats why you burn them first, believe me it works. and seeing as its not a car and the wheel can be taken out by undoing a bolt or quick release skewer its not really that hard is it? The boiling isn't neccesarily for the wd-40 but for any other crap that might be on the pads as well... in my case it was brake fluid that had been put onto the pads from my old dirty rotor. But burning the pads should get rid of the wd_40 because it should evaporate or just plain blow the shit out of most of it. Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted January 13, 2006 Report Share Posted January 13, 2006 Jesus Wept.... are you all mental.... I hope none of you every have a leaking brake caliper on your car. I can see you all trying to squeeze the fooking whole front wishbone suspension and disc into a bowl of water in your kitchen, while screaming..."No, No, Its alright mum, it works, I read it on the internet"If you have WD40 on your rotor, just use a degreasing agent, maybe thinners, Christ, even vinegar would also work. You don't need to boil the thing.... its the stupidest idea I have ever heard, a pure exercise is wasting time Boiling it won't displace WD40.... WD... Water Displacer ... Water can't displace it... ring any bells. Washing up liquid has degreassing properties, but its also soapy, and leaves a fine film, unless thoroughly rinsed.Again boiling pads won't remove any WD40 from them if its penatrated the compound, your not going to coax it out with water. The pads will pretty much be a write off. Using regular unleaded petrol on a cloth would help to considerably clean the surface, but again.... if its penatrated.Also ignoring the fact that car disc brakes are meant to have an oily residue, to stop the cast iron discs rusting. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted January 13, 2006 Report Share Posted January 13, 2006 isnt car fuel a form of light oil?to do with fraction distillation and all. just like oil but lighter?maybe im talking shit but meh.all you need to do is get a car of disc brake cleaner and follow the instructions sanding the pads before and after using the disc brake cleaner tends to work as the wd-40 wont have penetrated the whole of the pad. yer, it does mean the brake has to bed in again but it doesent exactly take long Will Quote Link to comment Share on other sites More sharing options...
Davetrials Posted January 13, 2006 Report Share Posted January 13, 2006 So is it safe or not. Ive done it about 6 times.twice to a hope mini, ive also set them on fire cleaned them with saopy water put em int oven, they all worked. Quote Link to comment Share on other sites More sharing options...
