CurtisRider Posted January 10, 2006 Report Share Posted January 10, 2006 righty not for a trials bike, but i want a strong chain all the same, but im unsure as to what to get?i have a bit of a fear of weak chains, which as really put me off running 9 speed, but trouble is its too costly to go to 8speed now cos id have to change loads, otherwise id run a kmc kool so what do you recomend? its for my kona stinky, and itll be running on a roadie cassetteive looked at whippermans, does anybody know where they stock the coloured ones, cos thatd be pimp any help would be much appreciated cheers, paul Quote Link to comment Share on other sites More sharing options...
TheMunn Posted January 10, 2006 Report Share Posted January 10, 2006 Yeah the whipperman chains are good, I used to run one on my trials bike. You could look at the better sram chains, they are good quality and strong. Quote Link to comment Share on other sites More sharing options...
Impacted. Posted January 10, 2006 Report Share Posted January 10, 2006 Chainreactioncycles do 9sp coloured wipperman chains. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted January 10, 2006 Author Report Share Posted January 10, 2006 (edited) Yeah the whipperman chains are good, I used to run one on my trials bike. You could look at the better sram chains, they are good quality and strong.money isnt really an object, well within reason, i will pay more for something that'll last and be safe Chainreactioncycles do 9sp coloured wipperman chains.NOTE:Chains in stock are not coloured. Edited January 10, 2006 by pauloliver Quote Link to comment Share on other sites More sharing options...
el curevo Posted January 10, 2006 Report Share Posted January 10, 2006 I shall be getting the sram pc911 chain. My mate has one and he says its brilliant. But atad expensive at £37.99. Quote Link to comment Share on other sites More sharing options...
shovel Posted January 10, 2006 Report Share Posted January 10, 2006 sram pc-990 chain, top of the range sram (apart from the hollow pin and stamped ones which are a little weaker just lighter and more expensive really) should last you pretty welli use the 8 speed equivalent, pc-68, for trials and never had any problems with it, snapped a couple of them before but just with me being stupid and not replacing it after it had stretched out Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted January 10, 2006 Author Report Share Posted January 10, 2006 I shall be getting the sram pc911 chain. My mate has one and he says its brilliant. But atad expensive at £37.99.ok when i say money isnt an object i didnt quite mean spending that much considering i would change the chain regularly(every 2 months seems ok?) to reduce unecessary sprocket wearsram pc-990 chain, top of the range sram (apart from the hollow pin and stamped ones which are a little weaker just lighter and more expensive really) should last you pretty welli use the 8 speed equivalent, pc-68, for trials and never had any problems with it, snapped a couple of them before but just with me being stupid and not replacing it after it had stretched out that chain looks to be ok, and isnt a bad price, any reason to spend a few quid more and get a pc991? Quote Link to comment Share on other sites More sharing options...
Ben Geary Posted January 10, 2006 Report Share Posted January 10, 2006 I hate scram chains i snapped 3 of them, They were good ones aswell.Go with a wiperman paul. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted January 10, 2006 Author Report Share Posted January 10, 2006 whippermans do look tempting, i have had the cheaper 8spd sram chains-15odd quid a time, and they lasted ok....i snapped 1 link a month roughly, which wasnt too bad for me at the time, but instead of buying a new chain i used to just rejoin it with a fresh link do kmc make any good 9spd chains? just that the kool chain is soooo good, so im guessing they cant be too bad? Quote Link to comment Share on other sites More sharing options...
Shaun H Posted January 10, 2006 Report Share Posted January 10, 2006 (edited) Don't even look at Shitmanos, in my opinion they should all be melted down before they do someone damage, my "XT" or whatever code it's got now snapped going downhill I'm yet to have any Sram chain snap on me and I've used the bottom of the range and almost top of the range versions. Any of them will do you good EDIT: forgot to add, the powerlinks are *really* useful in my opinion, but they are known to occasionally shake loose when freewheeling on DH. I've only had it happen to me once and that was on a really worn chain so not overly worried, I'll always run with one in but don't forget it's easy to leave it out if you wish Edited January 10, 2006 by Shaun H Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted January 10, 2006 Author Report Share Posted January 10, 2006 cheers shaun, i wasnt even going to consider a shitmano chain, mainly due to the annoying link pins, i also never use the split links, as ive had nothing but trouble with them its not hard to carry a chain breaker anyway so it seesm to be down to sram or whipperman now it seems, whippermans look very tempting, and seem to have a ganeral good review over all their range, whereas sram have the occasional wank chain it seems Quote Link to comment Share on other sites More sharing options...
Impacted. Posted January 10, 2006 Report Share Posted January 10, 2006 Hah, sorry about that, those wankers at CRC should put a picture of the non coloured ones on there.Anyway seeing as i'm here i'll go and reccomend sram chains, even though I've had one snap on me twice on my XC bike (top of the range one too with the holes in it and all) I still think they're damn good chains and they're thinner than shimano chains (which are shit by the way) so they'll be better for a 9 speed setup. Quote Link to comment Share on other sites More sharing options...
