No Need Of Gears
Enigma
Use your old cable to hold the mech in place, what you need to do is just get the inner cable and put it in the hole in the mech at the barrel adjuster, move the mech to where you want it with your hand, then tighten the cable where the mech sits, sorted. You can also use the barrel adjuster to move it up or down one gear on your cassette.
