Will Arnold Posted January 9, 2006 Report Share Posted January 9, 2006 read this, http://www.trials-forum.co.uk/forum/index....showtopic=69013then reply in here please Will Quote Link to comment Share on other sites More sharing options...
GlynnP Posted January 9, 2006 Report Share Posted January 9, 2006 i can only say from seeing pics but they look liek they line up nicely is there any reason for this post? did u last 1's not because i knwo i had problems wit the echo team setingup nicely did take awhile to get them set up Quote Link to comment Share on other sites More sharing options...
ARSE! Posted January 9, 2006 Report Share Posted January 9, 2006 Mine seems to be fine its quite close to the top but does not hit the tyre, why do you ask. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted January 9, 2006 Author Report Share Posted January 9, 2006 i asked because i have had problems with setting up brakes when the chain is tight with older frames that i have had.cheers.Will Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 9, 2006 Report Share Posted January 9, 2006 You mean the back wheel all the way in the frame?Yes you have no problem unless the moutns are off angle due to the frame builder.You also have 2/3mm of up and down movement on the salves of a Magura in the mounts.Pete Quote Link to comment Share on other sites More sharing options...
