Will Arnold Posted January 9, 2006 Report Share Posted January 9, 2006 (edited) right, i might be getting either a koxx xtp '05 or '04. or a gu typhoon 20" soon.my question is, if anyones built up a gu, do the brakes setup properly? i.e do the brake mounts sit at the right position with the chain tight?does the brake pad rub the tyre atall? or fall off the bottom of the rim?thanksWill Edited January 9, 2006 by WILL ARNOLD Quote Link to comment Share on other sites More sharing options...
