Anyone With Pures And A Louise!
Big_J
hey all,
i am currently running echo pure forks on a magura louise.
since i have been running this set-up, i have been having problems with my cones and axel in my front hub, no matter how tight i put my cones, they still felt loose. so i changed the fornt wheel, and even with this new front wheel, it still feels the same, and i am wondering wheather its to do with the brake and fork set-up i have. (currently running an 03 caliper louise dual-pot)
does anybody else have this problem?!
any tips on how to stop this?!
thaks all,
jak
i have some pure forks on my pitbull and an avid disk, and i used to think my front wheel was loose when i was on the back wheel, but if you look at someone when they are hopping on the back wheel with echo forks, they flex a bit to stop them from snapping when you do big moves, so it gives the feeling that something is loose, strange i know but once i seemed to get this fact into my head i stopped feeling it.
everything is all tight and straight on it, and the wheel fits in the forks fine, but its just that when i put the wheel in, its all staright and is inline with the centre of the forks, but when i pull my brake its "lop-sides" to the left, and then when i feel my wheel in the forks it feels as if my cones are loose in my hub, when they arent?!
and ideas?! :ermm:
jak (Y)
Ps. is that a mayor hint to buy your forks biguss?! ^_^
No............. :shifty:
but, what it could be is that the skewer is not holding the wheel in the forks tight enough, i had this problem with my avid and Urban forks i had a while back, when i applied the front brake it would move the whole wheel in the dropouts, what i ended up doing was tapping the axle and bolting the wheel into the dropouts, i have had no trouble with this since then :)
Adam
PS: buy my forks, much nicer than pures (Y)
Adam
ahh good thinking biguss, will try that! (Y)
thanks for all the replies!
jak
