Little Help Please Guys
bikerdude2006fr
Been a long time since I've used WMM but if I remember correctly... if you just make a folder in the collections column called whatever, say, 'clips' and then just import all the video files into that folder, it should be a bit neater. Having said that, I'm pretty sure that they will still be seperate subfolders for each clip in that main parent folder you made.
So to answer the question; you can't prevent the folders appearing, but you can easily organise/neaten them up a bit.
