Koxx Levelboss Mod
weebryan
I got a levelboss frame kit and i used tensile cranks but the chain was rubbing on the frame and had to change the tryall bottom bracket to a shorter one and still was rubbing and tried a few others. Ended getting a handfull of spacers to get a small clearance what a nightmare!!!!!
Are you sure that:
The cog was screwed on the right way?
The chain was tight?
The correct length (as mattyboy said) ie a longer works?
If they're all yes then I can't see how or why you have a problem as there are many people on this forum with LB mod's + tensiles who dont have problems :S
Can you post a picture or be more specific as to where the chain is rubbing? might be more useful :)
thanks :D
the chain was rubbing just above the rear axel at the chain stay welds on the inside of the frame. it also could be the onza hub that i used. it was a 122 tryall bb that came fitted on the frame kit
Edited by weebryan
