koxx1 Posted January 7, 2006 Report Share Posted January 7, 2006 hi there,my magura louise has just started slipping it isn't to bad but it isn't to good if you know what i mean, well anyway i was just wondering what to do... is it time for some new pads? and if i do need some new pads how would i wear them inthanks alot, nick Quote Link to comment Share on other sites More sharing options...
Littleharrys Posted January 7, 2006 Report Share Posted January 7, 2006 (edited) It may not really be a problem with the brakes. It may just be that the brake surface is dirty. Try giving it a good clean and dry it off with a clean rag. The pads may have pick up some oilly crud off the road etc.H Edited January 7, 2006 by Littleharrys Quote Link to comment Share on other sites More sharing options...
koxx1 Posted January 7, 2006 Author Report Share Posted January 7, 2006 It may not really be a problem with the brakes. It may just be that the brake surface is dirty. Try giving it a good clean and dry it off with a clean rag. The pads may have pick up some oilly crud off the road etc.Hi have cleaned them i shall let you know if it worked after i get back from riding later on cheers Quote Link to comment Share on other sites More sharing options...
Original Posted January 7, 2006 Report Share Posted January 7, 2006 Hi there, Best thing to do really is try to burn/bake the pads to get rid of the top layer of the pad. I'm not quite sure on how to go about this but i have heard that you stick the pad's in the oven for 10 minute's or so and then while they are bakeing to scrub the rotor with hot soapy water and leave to dry.About bedding the disc in slap some wet sloppy mud all over it and race down a hill holding the brake on shud sort it out a charm Hope i have been of some help!Original. Quote Link to comment Share on other sites More sharing options...
ZeroMatt Posted January 7, 2006 Report Share Posted January 7, 2006 When i first had my louise it used to slip loads, but then i snapped the lever off (be warned dont pull too hard on the lever) and i bodged a v brake lever onto it and it is fairly solid now. Quote Link to comment Share on other sites More sharing options...
