weebryan Posted January 6, 2006 Report Share Posted January 6, 2006 do you have to grind the anodised finish of the rim to use a hs33 and are they strong Quote Link to comment Share on other sites More sharing options...
el curevo Posted January 6, 2006 Report Share Posted January 6, 2006 Not sure how good the rim is, koxx are usually pretty good, but if the rim has a full braking surface you shouldnt need to grind the paint off. It will eventually rub away. Quote Link to comment Share on other sites More sharing options...
Trials Dave Posted January 6, 2006 Report Share Posted January 6, 2006 you can grind it if you want, but the paint wont effect braking too badly. just leave it. Quote Link to comment Share on other sites More sharing options...
wayn3 Posted January 6, 2006 Report Share Posted January 6, 2006 My mates seem strong enough and the paint just rubs off after a bit . Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted January 6, 2006 Report Share Posted January 6, 2006 yes u do and they r strong Quote Link to comment Share on other sites More sharing options...
andypro1 Posted January 6, 2006 Report Share Posted January 6, 2006 u dont have to do a grind the paint of but if u want a grind it wount harm it Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted January 6, 2006 Report Share Posted January 6, 2006 (edited) If your wanting to run a smooth rim, then just leave the rim as it is, and just leave the rim as normal, and wait till the anodised paint wears away (should take around 5 weeks)If your wanting to run a grind, just grind the rim as normal, and the paint will come off and it will be like a normal rim I advise you to grind it off though Ah, just noticed your using a front rim.Just leave it and use it with the paint on Edited January 6, 2006 by terror-error Quote Link to comment Share on other sites More sharing options...
weebryan Posted January 6, 2006 Author Report Share Posted January 6, 2006 thanks guys dam koxx bikes i had a onza 31mm rim and the brakes didnt reach Quote Link to comment Share on other sites More sharing options...
joe_eyre Posted January 6, 2006 Report Share Posted January 6, 2006 u can also do a light sand paper grind to fetch off and lacquar or paint Quote Link to comment Share on other sites More sharing options...
matt rushton Posted January 6, 2006 Report Share Posted January 6, 2006 you dont have to grind it away but the brake will probabley wear the paint away and make it look a mess Quote Link to comment Share on other sites More sharing options...
