SCOTTY___ Posted January 4, 2006 Report Share Posted January 4, 2006 Right heres my dilema...I have Monty ISIS cranks and i run a front freewheel..Im Swapping my 05 Echo frame with a guy for an 05 Short ZOO! python.As you know the the 05 Python has NO bashgurad so a bashring is needed... As i said previously i have month cranks and run a front freewheel. So has anybody run THIS successfully with monty cranks and a freewheel?If you have Monty cranks on an 05 Python what bash do you or a friend use?Thanks in advance...Scotty Quote Link to comment Share on other sites More sharing options...
Swize Posted January 4, 2006 Report Share Posted January 4, 2006 Ive seen it being run and its fine, you may need a longer bb though?Sam Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted January 4, 2006 Author Report Share Posted January 4, 2006 I have an FSA Platimium Pro BB its 113mm i think the longest one they doo..Would it fit?Cheers for the info Anyone else?Scotty Quote Link to comment Share on other sites More sharing options...
Swize Posted January 4, 2006 Report Share Posted January 4, 2006 I have an FSA Platimium Pro BB its 113mm i think the longest one they doo..Would it fit?Cheers for the info Anyone else?ScottyIme sure they do a 128mm? But can you not do something like mesure the room the freewheel has till it touches the bb cup you will need about 8mm spare to run a bashgard.If you understand what I mean Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted January 4, 2006 Report Share Posted January 4, 2006 i doubt that a 113mm would do it...128 is usually close...adam Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted January 4, 2006 Author Report Share Posted January 4, 2006 (edited) Its a 68 x 118mm..... ?That any good? Or will i need a new BB now Ive had a search and the only BB i can find is a Try-all and Echo that has a 68 shell and a lenth longer than 118? and there £55+!! And its abit an the heafty side!! You sure 118 wont fit?Thanks a bunch...Scotty Edited January 4, 2006 by Echo_Scotty Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted January 4, 2006 Report Share Posted January 4, 2006 Yeah it wont fit, you'll be needing a 127.5 or 128 Quote Link to comment Share on other sites More sharing options...
squince Posted January 4, 2006 Report Share Posted January 4, 2006 My mate paddy has an 04 Zoo python and he runs monty cranks with thischeers andy Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted January 4, 2006 Author Report Share Posted January 4, 2006 My mate paddy has an 04 Zoo python and he runs monty cranks with thischeers andyIsnt that the really large one though? that are made for 26"??Cheers Scotty Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2006 Report Share Posted January 4, 2006 Tartybikes do 128mm FSA BBs, which you'll need. Your freewheel's going to be moved across 4-6mm by having a bash on, so you really do need a new BB. Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted January 4, 2006 Author Report Share Posted January 4, 2006 Tartybikes do 128mm FSA BBs, which you'll need. Your freewheel's going to be moved across 4-6mm by having a bash on, so you really do need a new BB.Are you sure? I cannot find them on the BB page?! Also Are the 68mm shelled one's??ThanksScotty Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2006 Report Share Posted January 4, 2006 They're not on there 'cos they're not on there. Try calling them. Anyway, they're done in 73mm size, but come with the 2.5mm wide spacer to reduce it to 68mm. Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted January 4, 2006 Author Report Share Posted January 4, 2006 They're not on there 'cos they're not on there. Try calling them. Anyway, they're done in 73mm size, but come with the 2.5mm wide spacer to reduce it to 68mm.What do you mean with the spacers They go on the inside of the frame? Im asuming here that the 68mm is the BB shell on the frame?can you shed some light please? Im intreaged(sp?)Scotty Quote Link to comment Share on other sites More sharing options...
Swize Posted January 4, 2006 Report Share Posted January 4, 2006 What do you mean with the spacers They go on the inside of the frame? Im asuming here that the 68mm is the BB shell on the frame?can you shed some light please? Im intreaged(sp?)ScottyI think he means the legnth of the bb shell, not the width?Sam Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted January 4, 2006 Author Report Share Posted January 4, 2006 Ok im totaly at a loss here... So the 68mm shall we say isnt the Radius of the BB shell? (Circle bit) Its actualy the lench of it? Am i correct in thinking that? Also where would the washeres go? On the Splines or actually inside the bb shell somehow??Thanks..Scotty Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2006 Report Share Posted January 4, 2006 That's the width of your BB shell (from left to right). The spacer goes around the main body of the BB, on the r-hand side so it fits in between the edge of the shell and the larger right-side lip of the BB's body. Quote Link to comment Share on other sites More sharing options...
SCOTTY___ Posted January 4, 2006 Author Report Share Posted January 4, 2006 Right ive E-mailed Tartybikes and they say that the have the FSA bb in stock as Mark said (Thank You Very Much).... And its an FSA Platinum Pro DH... For £45? Is that good value? And it also includes the spacers...And its a full £10 Cheeper than the Koxx BB...!But im guessing i will need to telephone order... Havent done that in a while..!Cheers for the help people!! Specially OnzaBoyMark for the exerlant info on the FSA bb... Scotty Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted January 4, 2006 Report Share Posted January 4, 2006 It's good value, because it's pretty much the same as the koxx one I believe and they're supposed to be pretty good BB's. Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 4, 2006 Report Share Posted January 4, 2006 That's the right price, yeah. ISIS BBs suck cock and balls for how expensive they are, but that's life I suppose. Can't complain until I can prove I can make myself a top-qual ISIS BB for less than that I suppose Quote Link to comment Share on other sites More sharing options...
