Chris@Onza rider Posted January 2, 2006 Report Share Posted January 2, 2006 hey ladsI've asked a few of my mates and I have looked in the pad review section in here but cant find the answer to my question and my mates arent to sure.I have some short orange monty pads and I am running them on a monty phatso rim, the rim has no grind and the brake is shite, I have a booster so I no its not the magguras faulght, so I would like to know what are monty pads like on a grind? I dont want to grind my rim and then have to by new pads tommorow because mine have dissapeared into a grind.Thanks alot for your help guys.Tom Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted January 2, 2006 Report Share Posted January 2, 2006 I hear the X lites rip off the backings, I think Dave Marshall has a few to talk about. Quote Link to comment Share on other sites More sharing options...
Ali C Posted January 2, 2006 Report Share Posted January 2, 2006 on sharp grinds you will be lucky to get a week from them.I found mine worked really well on a smooth or slightly ground rim, give everything a clean and try them again Quote Link to comment Share on other sites More sharing options...
mat hudson Posted January 2, 2006 Report Share Posted January 2, 2006 lightley grind your rim then scrub it with blacks a few time down a big hill. then when its workn down put the hydras on. Quote Link to comment Share on other sites More sharing options...
Chris@Onza rider Posted January 2, 2006 Author Report Share Posted January 2, 2006 how do i get a smooth grind Ali? I thought there wasonly one level of grind...... shart and erm sharp?Ive tryed everytihng i can think of apart from a grind. Quote Link to comment Share on other sites More sharing options...
Ali C Posted January 2, 2006 Report Share Posted January 2, 2006 well, I have never done a smooth grind, but I recken only just touch the grinder on the rim, just enough so it marks it, but no more. Quote Link to comment Share on other sites More sharing options...
Chris@Onza rider Posted January 2, 2006 Author Report Share Posted January 2, 2006 Ah cool ill go give that a grind because yeh i know what you mean. Ill go and give it a practice . Quote Link to comment Share on other sites More sharing options...
mat hudson Posted January 2, 2006 Report Share Posted January 2, 2006 or use that snake grind thing someone did on their front rim on here.kinda did -._.-._.- on their rim with a grinder. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 2, 2006 Report Share Posted January 2, 2006 how do i get a smooth grind Ali? I thought there wasonly one level of grind...... shart and erm sharp?Ive tryed everytihng i can think of apart from a grind.If you can, get a disc with a very fine compound if you know what i mean, you want the smallest grit particles in it possible. Also, put the grinder up to full speed, the faster the better, and then just barley touch the grinder to the rim.Id try cleaning the rim up and the pads first of all though. Quote Link to comment Share on other sites More sharing options...
munkee Posted January 2, 2006 Report Share Posted January 2, 2006 For a really fine grind use the diamond edged cutting discs (usually for masonary) Quote Link to comment Share on other sites More sharing options...
