Zona Zip Chain Problems
joewhite
What gearing are you running? - 12 18?
What chain?
Try getting the longest BB available, ChainReaction have one Here
Link should add the correct one to shopping basket
If not, get the: UN53 Sq Taper 68-127.5mm.
That's what I'm running on my Zona with Sq taper Echo cranks. (also with KMC Kool K710)
Percect. (Y)
Yep, they're 15mm or so shorter than the CLS Python too. Probably why it doesn't ride like shit :lol:
Anyways, you may have to invest in a smaller rear freewheel, basically. If you get a 16t rear you could run 20:16, which might be OK. Try and get the ratio to as near as 1.5 as possible (by dividing the front gear by the rear), as that's the ideal ratio for mod pretty much.
Like I said - if you've got the money, trying going for 20:16, basically. That should work out OK, pretty much. It'll be a little easier to pedal than a standard mod gear, but you'll need a 15t freewheel to work it out properly otherwise, so you'd need a flip-flop hub...
So yeah, 20:16.
