King C Posted December 31, 2005 Report Share Posted December 31, 2005 Ive just built my first mod bike after having bought my first bike, and I now have a bit of a problem. I have had to shorten my chain and I can't seem to find the right length. I've got it almost right. When I add 1 link its too long for my chain tensioners and when I remove 1 its too short and the brake pads don't line up properly. Quote Link to comment Share on other sites More sharing options...
steve huddo Posted December 31, 2005 Report Share Posted December 31, 2005 Im having problems and allAhh well !!! Quote Link to comment Share on other sites More sharing options...
011001000110010101110010 Posted December 31, 2005 Report Share Posted December 31, 2005 (edited) Yes, this appears to be a generic problem with most mod frames. The real problem is becuase there is not enough adjustment for the rear wheel. You may have to run it loose for a while and just ride around in circle while it stretches allowing you to take a link out. Or find a half link for your chain and that should solve the problem, if you can find one that is. Edited December 31, 2005 by derf Quote Link to comment Share on other sites More sharing options...
King C Posted December 31, 2005 Author Report Share Posted December 31, 2005 (edited) Yes, this appears to be a generic problem with most mod frames. The real problem is becuase there is not enough adjustment for the rear wheel. You may have to run it loose for a while and just ride around in circle while it stretches allowing you to take a link out. Or find a half link for your chain and that should solve the problem, if you can find one that is.The chain is quite old. do you recommend a new chain? cos that was my original thought just didn't get round to doing it. Edited December 31, 2005 by kcchan Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted December 31, 2005 Report Share Posted December 31, 2005 What gearing do you have? Quote Link to comment Share on other sites More sharing options...
King C Posted December 31, 2005 Author Report Share Posted December 31, 2005 What gearing do you have?18:12 Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted December 31, 2005 Report Share Posted December 31, 2005 front freewheel or fixed with profile/king? Quote Link to comment Share on other sites More sharing options...
King C Posted December 31, 2005 Author Report Share Posted December 31, 2005 front freewheel. by profile/king you mean hubs don't you. If so then its neither its a mission hub w 14mm axel (really annoying) Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted December 31, 2005 Report Share Posted December 31, 2005 Try and get a 13t rear cog and it will get your chain to the right length Quote Link to comment Share on other sites More sharing options...
King C Posted December 31, 2005 Author Report Share Posted December 31, 2005 do you know where i can get 1 from cheap, about £10. Quote Link to comment Share on other sites More sharing options...
011001000110010101110010 Posted December 31, 2005 Report Share Posted December 31, 2005 Changing the gear ratio is not the correct way to do it, it will work yes. But a new chain, when it is stretched should be fine. But the wheel will probably be right at the front or the rear of the dropouts in the frame.Another option would be to connect the chain whilst its off of the sprokets then pedal it on unless its way too tight this can also work. Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 1, 2006 Report Share Posted January 1, 2006 His chain is already stretched. Quote Link to comment Share on other sites More sharing options...
the judge Posted January 1, 2006 Report Share Posted January 1, 2006 "Another option would be to connect the chain whilst its off of the sprokets then pedal it on unless its way too tight this can also work"i've heard that doing this can ruin the bearings in the bb/hub so be careful if you choose this option Quote Link to comment Share on other sites More sharing options...
011001000110010101110010 Posted January 1, 2006 Report Share Posted January 1, 2006 Yes, but if it isnt too tight you can "power through it" and it will sit nicely. Its a bit pot luck though. Quote Link to comment Share on other sites More sharing options...
wilky_mod_legend2 Posted January 1, 2006 Report Share Posted January 1, 2006 i would say, get a new chain,if its old anyways, dont want any more carnage , then try and undo 4 bolt mounts and put wheel in and a get a rough tentsion then set up brake, and adjust if needed, this worked for me,cheerswilky Quote Link to comment Share on other sites More sharing options...
