White Industries Or Eno?
ned1
which freewheel wud u recomend?
White industries make the ENO do they not?
I thought the choice would have been ACS or ENO?
That being the case ENO if cost isn't a factor, if it is, ACS will suffice.
Yeah i thought the same, :lol: ... it depends how much you are willing to spend on a freewheel?
ACS Claw = £12
WELDED ACS Claw = £14.99
White Industries (ENO) = £69.99
The ENO is deffo the best, and the normal ACS Claw is deffo the worst! The welded ACS Claw is just a much stronger version of the original, but it is much better.
Hope I Helped,
Sam (Y)(Y)(Y)
How does a weld make it stronger? I think your trying to say that when welded, the chances of it unscrewing are reduced, but it isnt any stronger as such.
Edited by jake1516
It doesn't change the strength at all :ermm:
It just stops the lockrings from losening themselves and falling apart.
The ENO's are very nice though, fitted one to a T-Mag at work today.
"Feels like sex!" -One of my collegues :P
If you have the money, got for the ENO (Y)
I know I was simply giving the guy a chance to explain his reasoning for it being stronger...
personally... (although the eno is far superior and seems like the best bet because it more expensive and has more engagements) i would go for the acs first... u shouldnt just buy it because it has more engagements. You will find yourself relying on the engagements rather than ur technique. Its worth perfecting ur technique first and then upgrading... i dont know if i make sense? but this is my opinion, i dont want people taking the mick because theres no comparrson between the 2 in quality, just think about what im saying? because i went from 16 to 36 engagements points and found my gapping improved, but i was already acheiving 6-7 ft gaps on 16 engagements... so its about the technique more than engagements, cant wait till i get me eno now that i feel that i have my tehcnique sorted :D
also it does take a while to get used to the extra engagements....
