Echo Team 2-bolt
fredrico
Does any one know if the echo team 2-bolt booster will work on a hs33 using the v brake adapter. The bike is a 26" but it looks as if it should work. The distance from the two top mounting bolts (where original magura booster went) is 101mm.
Cheers (Y)
Edited by fredrico
