Jonas Posted December 28, 2005 Report Share Posted December 28, 2005 Just got me a new variable speed grinder: 2.800 - 11.000 rpm (Disc size: 125mm. Model: Skil 9385). Happy days! I'm going to do some experimenting with grinder speeds to see what works best, but thought I would ask you guys for a good headstart. Setup: Pads are Koxx Browns and the rim is a DX32 (might try the new Echo drilled one next time). Grinder discs are generic metal gutting discs and I will be using fresh (not rounded/worn) discs. (Not running a booster as of now but will get a Echo control when the shop restocks them in late Januari. Also, if it matters, the frame is a Levelboss and the brake is a 2005 HS33.) That should be EVERYTHING that is relevant about the bike i think... Thanks! Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted December 28, 2005 Report Share Posted December 28, 2005 i think mine runs at 11,000 and it seems to work well but maybe less is better, i really haven't experimented. not much use am i Quote Link to comment Share on other sites More sharing options...
benno Posted December 28, 2005 Report Share Posted December 28, 2005 I would have thought slower speeds would work better, as they'd give you a rougher finished than higher speeds. Try it out and see I guess. Quote Link to comment Share on other sites More sharing options...
Hobnobs Posted December 28, 2005 Report Share Posted December 28, 2005 There was a thread before somewhere, try the search, i think we as a whole decided slower was better Quote Link to comment Share on other sites More sharing options...
Jonas Posted December 28, 2005 Author Report Share Posted December 28, 2005 (edited) i think mine runs at 11,000 and it seems to work well but maybe less is better, i really haven't experimented. not much use am i Yeah, I borrowed a 11krpm from my father and sure it works. But I've heard that a lower speed might be better - can't remember the details though. After all the "normal" 11krpm grinders weren't really designed with "optimum grinding speed" in mind. Probably I will get the extra power I crave when the booster arrives. But even if it will work fine then, even better is always nice. You can't get enough of the good stuff. Hobnobs + benno: I found this topic (that's where I got the idea to try from) but it's not very specific, might be that no one has really experimented much? Of course I will try for myself, but as I stated a head start is always nice. EDIT1: Hobnobs and benno where to fast for me. EDIT2: Clicky didn't work. Edited December 28, 2005 by Jonas Quote Link to comment Share on other sites More sharing options...
SQuiT-man Posted December 28, 2005 Report Share Posted December 28, 2005 I think mine is 11,000 rpm, but I'd say use a slightly thinner dics (but not the ultra-thin ones, they dont work well for me!), as they dont round off so badly on the edges, and stay a bit sharper. Then perhaps try something like 8 or 9,000 rpm? Try it and see what works best for you, especially if you got an old rim kicking about somewhere! Quote Link to comment Share on other sites More sharing options...
