Luke Williams! Posted December 25, 2005 Report Share Posted December 25, 2005 Just wondering when they will be released? how much for? and mostly where from!am i correct in assuming the geo is wheel base 1075BB +35chain stays 380mm thanks luke Quote Link to comment Share on other sites More sharing options...
Martin Grainger Posted December 27, 2005 Report Share Posted December 27, 2005 (edited) there may be some news on here :aorta bikeEDIT: this one works! www.aortabike.com Edited December 27, 2005 by Martin Grainger Quote Link to comment Share on other sites More sharing options...
Luke Williams! Posted December 27, 2005 Author Report Share Posted December 27, 2005 Website seems to all be in japanese or what ever its in wont show up as english on my browser only some parts are english the main details arnt Quote Link to comment Share on other sites More sharing options...
Tomm Posted December 28, 2005 Report Share Posted December 28, 2005 The site doesn't work properly for me either - I think it's the site though, not your browser. You gotta love the engrish on there too: "Make in China" and "Copy Right 2005 Aortabike Allright Reserved" Quote Link to comment Share on other sites More sharing options...
Shaun H Posted December 28, 2005 Report Share Posted December 28, 2005 Sounds like he needs a lesson in Dengish... Quote Link to comment Share on other sites More sharing options...
Backgren Posted December 28, 2005 Report Share Posted December 28, 2005 In (D)English: AORTA 26 inches frames frames: Spread of axies 1075mm, latter forks length 380mm, middle axle high 35mm, the frame has the certain length, but cannot too long control with difficulty, the middle axle obviously is higher than the core, but cannot excessively be high, can adapt each kind of different type slighting the law with the tidal current, specially suitablly slights the law the flexible rider. The frame surface high polishes the titanium gray, the anti- oxide coating, will not be able to have the oxidized phenomenon in the course of time, some four nails oil will only check the place edition. Frame characteristic: Intensity extremely high, the process intensity test, is hard incomparably, highly anti- turns the nature, the entire vehicle cannot become tender, is hit not not instable. It certainly doesn't make much sence.... Quote Link to comment Share on other sites More sharing options...
Luke Williams! Posted December 28, 2005 Author Report Share Posted December 28, 2005 In (D)English: AORTA 26 inches frames frames: Spread of axies 1075mm, latter forks length 380mm, middle axle high 35mm, the frame has the certain length, but cannot too long control with difficulty, the middle axle obviously is higher than the core, but cannot excessively be high, can adapt each kind of different type slighting the law with the tidal current, specially suitablly slights the law the flexible rider. The frame surface high polishes the titanium gray, the anti- oxide coating, will not be able to have the oxidized phenomenon in the course of time, some four nails oil will only check the place edition. Frame characteristic: Intensity extremely high, the process intensity test, is hard incomparably, highly anti- turns the nature, the entire vehicle cannot become tender, is hit not not instable. It certainly doesn't make much sence.... i made out some of it i think he is mostly saying about why he has chose the geo fro the frame i.e. "the frame has the certain length, but cannot too long control with difficulty" think he means you dont want the frame too long so you cant control the bike but long enough to get the beniftis of a long frame.lol other than that its no sense Quote Link to comment Share on other sites More sharing options...
Dan@Trials-uk Posted December 28, 2005 Report Share Posted December 28, 2005 He has most likely typed it all up in cantonese, then used a language translator to translate to English. Quote Link to comment Share on other sites More sharing options...
billocks Posted December 30, 2005 Report Share Posted December 30, 2005 He has most likely typed it all up in cantonese, then used a language translator to translate to English. you say english? Quote Link to comment Share on other sites More sharing options...
Waynio Posted December 31, 2005 Report Share Posted December 31, 2005 even german is more presentable than that lol.Waynio.............................its deffinatly not right it could take some people days to work out that, then think about buying one. haha Quote Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2005 Report Share Posted December 31, 2005 In (D)English: AORTA 26 inches frames frames: Spread of axies 1075mm, latter forks length 380mm, middle axle high 35mm, the frame has the certain length, but cannot too long control with difficulty, the middle axle obviously is higher than the core, but cannot excessively be high, can adapt each kind of different type slighting the law with the tidal current, specially suitablly slights the law the flexible rider. The frame surface high polishes the titanium gray, the anti- oxide coating, will not be able to have the oxidized phenomenon in the course of time, some four nails oil will only check the place edition. Frame characteristic: Intensity extremely high, the process intensity test, is hard incomparably, highly anti- turns the nature, the entire vehicle cannot become tender, is hit not not instable. It certainly doesn't make much sence....Its like onve them tatoos people get with chinese writing thinking it means something devine only to find out when they get home that it means 'my tits are sagging' (specifically thinking about slegs with tatoos on their lower back) Quote Link to comment Share on other sites More sharing options...
