bhups Posted December 24, 2005 Report Share Posted December 24, 2005 helloMy back brake is not working as well as it should it slips a bit when you tooth pick and when slightly land on the edge or when you land really vertical but when you start going it gets better. i am running plazmatic crm's and a medium grind. i have cleaned the pads and rim, only had the pads about a week.any advice or help is much needed. Many thanks Bhups Quote Link to comment Share on other sites More sharing options...
koxx1 Posted December 24, 2005 Report Share Posted December 24, 2005 (edited) you need a harsh grind if your running plaz pads they should work well then.or maybe you just haven't set them up well enough? my brake was doing the exact same i set the brake up better applyed a dab of tar and its working fine. Edited December 24, 2005 by koxx1 Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted December 24, 2005 Report Share Posted December 24, 2005 What did you clean the pads with? Quote Link to comment Share on other sites More sharing options...
bhups Posted December 24, 2005 Author Report Share Posted December 24, 2005 i cleaned them with a damp cloth with a bit of fairy and sand paper Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted December 24, 2005 Report Share Posted December 24, 2005 Ahh right. I was hoping you were going to say something like that. If you use anything like WD40 etc, that's why you're brake'll be shit Errrmm...Try riding/pushing the bike along with the brake on, to dry up the rim, and spread all the fairy liquid round abit. One thing I found works aswell, is deodrant. Srap a bit over the rim, and any crap will literally rince (sp?) off the rim. Then just dry it, and ride Could also try a fresh grind? Quote Link to comment Share on other sites More sharing options...
bhups Posted December 24, 2005 Author Report Share Posted December 24, 2005 Did i clean them with the wrong thing???Bhups. Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted December 24, 2005 Report Share Posted December 24, 2005 Get a nice fine grind stuck on there mate My plaz pads worn down in like 3 weeks i was sooo f**king pissed off about that!!! But your shouldnt do that, aslong as your grind isnt as rough as mine was Quote Link to comment Share on other sites More sharing options...
