wayneone Posted December 24, 2005 Report Share Posted December 24, 2005 Right got my new t-rex went to set up the brakes but come accross a problem the maguras were pushed all the way in but there was still too small a gap to fit the pad in without it hitting the rim, In the end i had to remove some pad material to get it to work(about 1mm 1.5mm). Ive got hog and ronnie rims altho im not sure its a ronnie becuase its realy realy wide a lot wider than my old one, anyway this problem occured on both frame and forks just wondering if theres a fix or if ill just have to sand some off the pads all the time?And on another note i got some pink echo pads for free from tartybikes what are they like on a smooth rim? Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted December 24, 2005 Report Share Posted December 24, 2005 Right got my new t-rex went to set up the brakes but come accross a problem the maguras were pushed all the way in but there was still too small a gap to fit the pad in without it hitting the rim, In the end i had to remove some pad material to get it to work(about 1mm 1.5mm). Ive got hog and ronnie rims altho im not sure its a ronnie becuase its realy realy wide a lot wider than my old one, anyway this problem occured on both frame and forks just wondering if theres a fix or if ill just have to sand some off the pads all the time?And on another note i got some pink echo pads for free from tartybikes what are they like on a smooth rim?Try them? , I don't think they have been used much, or I just haven't seen any reviews etc...I don't know about the rim and magura problem sorry, but i'd like to know how good the pads are Mat Quote Link to comment Share on other sites More sharing options...
Simpson Posted December 24, 2005 Report Share Posted December 24, 2005 just make sure your cylinders are all the way outwards as they can be loosten it off and pump the lever which pushes the cyclinders outwards, never had new pads but my friend has a t rex with a ronnie and has no problems! Quote Link to comment Share on other sites More sharing options...
bikerboysam1 Posted December 24, 2005 Report Share Posted December 24, 2005 probably just sand down your pads mate, and i don't know about those pads, sorry Quote Link to comment Share on other sites More sharing options...
petit_pablo Posted December 24, 2005 Report Share Posted December 24, 2005 Looks like your going to have to sand down the pads each time chap.The hog is a wiiiddde rim! Quote Link to comment Share on other sites More sharing options...
