laurent Posted December 24, 2005 Report Share Posted December 24, 2005 Someone could tell to me if, the current Onza Hog Rear, have a line on sidewalls as Viz rim or as my 42 mm fu...ing try all rim?My try all 42mm rear is cracked on this line!So i whant replace my rear rim by an other rear rim.....but not a try all.I was interesteed in buying Viz 42mm or 46mm but they seems to have the same line on sidewalls!The new echo seems to be the strongest, but the the maximum wide allowed by my frame is 46/47mmAnyway , if you have a piece of advice for à strong 42/46/47mm rear rim...it'll be great!Otherwise....i'll buy dx32..... ( but they are not enough wide .... Quote Link to comment Share on other sites More sharing options...
Shaun H Posted December 24, 2005 Report Share Posted December 24, 2005 I'm fairly sure the 47mm Try-All rim doesn't have the "Apollo line" on it. Same with the hog I think. Quote Link to comment Share on other sites More sharing options...
laurent Posted December 24, 2005 Author Report Share Posted December 24, 2005 I'm fairly sure the 47mm Try-All rim doesn't have the "Apollo line" on it. Same with the hog I think.I think also that 47mm try all havent't this stupid line which make the sidwalls weaker!All Viz rims have this line?What are the strongest rim: between Onza and try all?There are other 38 to 47 mm rims? Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted December 24, 2005 Report Share Posted December 24, 2005 i dont think the onza one has a line Quote Link to comment Share on other sites More sharing options...
am4zin Posted December 24, 2005 Report Share Posted December 24, 2005 What is that line/groove there for in the first place? Is it a result from the manufacturing process of the rim or is it actually intended to be there? Quote Link to comment Share on other sites More sharing options...
dave85 Posted December 24, 2005 Report Share Posted December 24, 2005 Its a wear indicator, when it disappears its time for a new rim. Good theory for road and xc, bad for trials. Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted December 24, 2005 Report Share Posted December 24, 2005 Or... buy an Echo 48mm rim and file 1-2mm off your pads. Quote Link to comment Share on other sites More sharing options...
Josh Greenan!!!!!!!!!! Posted December 24, 2005 Report Share Posted December 24, 2005 I think also that 47mm try all havent't this stupid line which make the sidwalls weaker!All Viz rims have this line?What are the strongest rim: between Onza and try all?There are other 38 to 47 mm rims?I think the strongest is the onza that i know of but am not sure. Quote Link to comment Share on other sites More sharing options...
petit_pablo Posted December 24, 2005 Report Share Posted December 24, 2005 THe hog doesnt have that line on it. At least it didnt after a grind before it got to me. Quote Link to comment Share on other sites More sharing options...
bikerboysam1 Posted December 24, 2005 Report Share Posted December 24, 2005 yeh, i agree with most others---the hog definately doesn't have that line on it!!!!!! Quote Link to comment Share on other sites More sharing options...
Shaun H Posted December 24, 2005 Report Share Posted December 24, 2005 All Viz rims have this line? What are the strongest rim: between Onza and try all? As far as I know, yes all the Jiz rims have got wear indicators on the sidewalls. The two rims are very similar although the Onza material is supposed to be "harder" (nb - this does not nesccarily mean stronger). More significantly the Onza rim has eyelets for the spokes which in theory means the wheel can be built with higher tension and therefore the wheelbuild, not nesccarily the rim (confused yet?) will be stronger than the Try-All's. Quote Link to comment Share on other sites More sharing options...
