trialsinchris Posted December 18, 2005 Report Share Posted December 18, 2005 Hi, Just wonderin, when i put my front brake on full my bike it still seems to rock back and forwards is this because the headsets loose and if so would the ddg dreadlock off of tartybikes stop this and how do you fit them. cheers Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 18, 2005 Report Share Posted December 18, 2005 Right, first things first - the "lock front brake and rock bike" technique isn't that great for checking your headset. Your pads may be rocking in your disc caliper/Magura, your wheel bearings might be f**ked, etc. It's not a great way of checking it. Anyways, just loosen the two stem bolts (usually two, anyway) behind the steerer tube. Then, tighten up the top cap bolt a little. Tighten the stem up again, and see how that goes. Quote Link to comment Share on other sites More sharing options...
trialsinchris Posted December 18, 2005 Author Report Share Posted December 18, 2005 Thanks but tried that and top cap bolt just spins i think its come unthreaded, any help on what to do now Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 18, 2005 Report Share Posted December 18, 2005 Thanks but tried that and top cap bolt just spins i think its come unthreaded, any help on what to do now Is it super loose or something? Either way, it does sound like you may have f**ked the insert on the star-nut. I did with mine Basically, just try undoing the top-bolt. You may find it won't come out properly (mine certainly didn't), and if not, you'll have to try and prise the top-cap off the stem. This isn't fun, but you've got to do it. Then, you can just get a new star-nut and mash that into your stem on top of the old one. Worked for me Quote Link to comment Share on other sites More sharing options...
trialsinchris Posted December 18, 2005 Author Report Share Posted December 18, 2005 i have a few other bikes could i take one off of them and if so how and how to fit my my trials bike also if i prise top cap off will nut come with it Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 18, 2005 Report Share Posted December 18, 2005 i have a few other bikes could i take one off of them and if so how and how to fit my my trials bike also if i prise top cap off will nut come with it You won't be able to re-use a star-nut. The star-nut shouldn't and probably won't come off with the top-cap. Mine tore the star-nut a new arsehole and ripped the insert with it, but not the top and bottom plates. IT doesn't really matter about them though, to be honest. Either way, get yourself a new star-nut and just hit it into the forks. You may need to use an old bolt to have the head sticking up a little above the top of the fork (wehn the starnut goes underneath the edge of the fork) so you can hit it in further. Above all, keep it straight. Might be work getting your LBS to do, to be honest. Quote Link to comment Share on other sites More sharing options...
MaXsteri Posted December 19, 2005 Report Share Posted December 19, 2005 Save starting a new topic, if you tighten up a headset and then it loosens itself practically straight away what could be wrong? Bearings? Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 19, 2005 Report Share Posted December 19, 2005 Is the star-nut slipping up the inside of the steerer? Often the cause.Alternatively, strip your headset down. If it's sealed bearing, just hold the bearings in your hand and spin the inner with your other hand. If it's all notchy and tight and shit, it could be new headset time. By the same token, if it's super loose, then yeah - bearings it is. If it's open bearing, just clean the ball bearings, check them for wear, check the cups for any pitted parts or any obvious sign of wear, then reassemble and regrease.Check the star-nut though Quote Link to comment Share on other sites More sharing options...
deanie-b Posted December 19, 2005 Report Share Posted December 19, 2005 Headsets are one thing I don't enjoy tampering with ...Anything with bearings scare me, I get a mechanic's magnetic tray and hold it directly under the headset when i slacked it off, It catches the bearings a treat I use copper ease to lube them back in.£4.99 from speeding.co.ukTHIS SITE APPLIES TO CARS ONLY, THE DESCRIPTION SAYS USED TO REDUCE BRAKE SQUEAL.DO NOT USE COPPER EASE ON BICYCLES BRAKES. Quote Link to comment Share on other sites More sharing options...
mackey Posted December 19, 2005 Report Share Posted December 19, 2005 This sounds similar to a problem i had.What i had done was ripped the threads out of the star nut to fix this problem go to your local bike shop and ask for a new star nut these are about £3 and to fit it you knock your old one out with a screw driver then hit the new one in about 50mm and see if this fixes it, if not im not sure whats wrong sorry.Cheers Mackey Quote Link to comment Share on other sites More sharing options...
koxx1 Posted December 19, 2005 Report Share Posted December 19, 2005 ive always found a headlock works better than a star nut, mine was about £10 you can get from any decent bike shop nick Quote Link to comment Share on other sites More sharing options...
trials cred Posted December 19, 2005 Report Share Posted December 19, 2005 maybe you need some more spacers? Quote Link to comment Share on other sites More sharing options...
trialsinchris Posted December 22, 2005 Author Report Share Posted December 22, 2005 how do you fit headlocks then Quote Link to comment Share on other sites More sharing options...
