Trials Smithy Posted December 17, 2005 Report Share Posted December 17, 2005 Hi guys, I was looking at a KOT MS2 and have been wondering about the rear end, the wheel! Where i have looked it says you can run a maximum rim size of 47mm but a Echo drilled 06 rim is 48mm What i was wanting to know would it be possible to run a Echo rim? as 1/2 a mill each side cant make that much difference can it? And would a 2.5 maxxis tyre be able to fit? Cheers for the help guys Smithy Quote Link to comment Share on other sites More sharing options...
c.kezer Posted December 17, 2005 Report Share Posted December 17, 2005 Hi guys, I was looking at a KOT MS2 and have been wondering about the rear end, the wheel! Where i have looked it says you can run a maximum rim size of 47mm but a Echo drilled 06 rim is 48mm What i was wanting to know would it be possible to run a Echo rim? as 1/2 a mill each side cant make that much difference can it? And would a 2.5 maxxis tyre be able to fit? Cheers for the help guys Smithyi think you should be able to (i think ). if you have 1/2 mill at each side that should work. but the tire might not if it bulges out to much it will chatch and got any pics of the kot ms2 please.chris Quote Link to comment Share on other sites More sharing options...
Trials Smithy Posted December 17, 2005 Author Report Share Posted December 17, 2005 i think you should be able to (i think ). if you have 1/2 mill at each side that should work. but the tire might not if it bulges out to much it will chatch and got any pics of the kot ms2 please.chris I havent got one i am looking at one, but i want the echo rims and theres no point me getting a KOT if the rims im getting wont fit!CheeersSmithy Quote Link to comment Share on other sites More sharing options...
bikerboysam1 Posted December 17, 2005 Report Share Posted December 17, 2005 (edited) i think you should be able to (i think ). if you have 1/2 mill at each side that should work. but the tire might not if it bulges out to much it will chatch and got any pics of the kot ms2 please.chrisi agree with you, i think it should fit...and here's a pici don't know if that picture worked,so here's a linkhttp://tartybikes.co.uk/image.php?image=ms2-1.jpg Edited December 17, 2005 by bikerboysam1 Quote Link to comment Share on other sites More sharing options...
chrishayton Posted December 17, 2005 Report Share Posted December 17, 2005 its 1 mm it will be fine, if you have to sand .5mm off you pads. Quote Link to comment Share on other sites More sharing options...
smelly joe Posted December 18, 2005 Report Share Posted December 18, 2005 shouldn't be a problem if you are going to grind your rim, because the grind should slightly reduce the width of the rim. i don't really think that 1mm will make a whole lot of difference anyway Quote Link to comment Share on other sites More sharing options...
JonCongreve Posted December 18, 2005 Report Share Posted December 18, 2005 Hi.My mates got one and they ride realy nice. I would say that the rim would fit fine, but i'm not too sure about fitting a 2.5" tire, as my mate's 2.4" just fits. The one downside about the frame is how much the chainstays flex through braking, although you get this with alot of frames there is quite a bit of flex in this frame and a booster would help alot. Hope this has helped Quote Link to comment Share on other sites More sharing options...
