brian123 Posted December 16, 2005 Report Share Posted December 16, 2005 I saw a website (somewhere) that explains how to fit a new pair of forks.Has anybody seen it and knows the webby address?Just for info'Onza Fall Guy forks going in an Onza T-Comp frame using a Cane Creek S2 headset with Onza T-Master stem.Cheers Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted December 16, 2005 Report Share Posted December 16, 2005 Why? whats up with it, have you tryed to fit it yet? or is the steerer just popping out of the top of the stem?Mat Quote Link to comment Share on other sites More sharing options...
brian123 Posted December 16, 2005 Author Report Share Posted December 16, 2005 Why? whats up with it, have you tryed to fit it yet? or is the steerer just popping out of the top of the stem?MatYep, I want to make sure that I get the headset installed properly before I cut the tube down to the correct size... Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted December 16, 2005 Report Share Posted December 16, 2005 Yep, I want to make sure that I get the headset installed properly before I cut the tube down to the correct size...Well go down to your LBS and get somebody to fit the headset for you, and then pop the forks into the headset/frame and mark out where you want it cutting (with all the spacers etc.)Then cut away, remember to nock the star nut down and cut about 2-3 mm under the line so you have room for your top-cap, hope i explained correctly.Mat Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted December 16, 2005 Report Share Posted December 16, 2005 In my experiance its best to let your local bike shop do that. The "Correct" way is with a head set press which I've never seen but im guessing it works similar to a pillar drill.When you said "installed properly" is there something which tells you it ISN'T installed properly? Quote Link to comment Share on other sites More sharing options...
Callum Trialsin Posted December 16, 2005 Report Share Posted December 16, 2005 just send it into your lbs and then u wont waste your money by putting it in wrong and breakin it easyist thing Quote Link to comment Share on other sites More sharing options...
brian123 Posted December 16, 2005 Author Report Share Posted December 16, 2005 Found ithttp://www.canecreek.com/cc_headset_manuals.htmlThanks for the LBS advice but I like to do things myself, if I bugger it up then I'll take it to the shop Quote Link to comment Share on other sites More sharing options...
Callum Trialsin Posted December 16, 2005 Report Share Posted December 16, 2005 Found ithttp://www.canecreek.com/cc_headset_manuals.htmlThanks for the LBS advice but I like to do things myself, if I bugger it up then I'll take it to the shop thats how i was until i f**kd up a pair a 24seven bmx cranksStill try and do every thing else just ask people first if im stuck like u Quote Link to comment Share on other sites More sharing options...
brian123 Posted December 19, 2005 Author Report Share Posted December 19, 2005 (edited) Managed to fit the forks without breaking anything I've only had 10 minutes on the bike so far, it feels so weird, very small and very light. It weighs 18 lbs and just needs a rear maggie now.What do you think of it? Edited December 19, 2005 by brian123 Quote Link to comment Share on other sites More sharing options...
bikerboysam1 Posted December 20, 2005 Report Share Posted December 20, 2005 wow, that looks like a pretty sweet ride!!!!nice one mate, keep it up Quote Link to comment Share on other sites More sharing options...
