Normal P.s.i For Everyone
durkadurka
Hiya guys
I was wondering what tyres and tyre pressures you are all using. As i have a Maxxis High Roller 2.5 and have it really soft. For some reason, it seems to sound really harsh when i do anything. (its not becuase im a harsh rider)
I was wondering if it had anything to do with the 'eg, 60a' hard compound of my tyre.
Does this happen to anyone else??
Much Abliged
Adam (Adz) (Y)
ok i used to run about 18psi on a ronnie with a intense tyre with a 3 inch tube and i stuck to walls like spider man but after a couple of big ish hard landing gaps i found out that it was a little to soft and i now have dents in my rim (N) i now run around 27-29 psi with the same tube and tyre and i still stick on walls but my balance has improved so much eg on the backwheel with the bake brake off for a couple of seconds (Y)
just go out ride a curb but adjust your pressure aslong as you have a pump it wouldnt hurt anyone will it
hope this helps mate
ric
