Dicta Freewheels
Swize
Need to remove a 15th dicta .
Well ive been to halfords and the local bmx shops.
They can't take it off it off becuase its a 15th, then the axle is too big for the tool.
So what next do i run out side and grab the grinder?
Can i do anyother bodges ?
Would clamping the freewheel in a vice and turning work?
Well sam need help :( anyidears and i don't want to buy a tool.
Edited by samthebiker
grinder, not gonna be worth anything in one piece anyway
I dont understand how you could get the freewheel off without danaging the threads its attached to if he uses a grinder?
You couldnt elaborate a little at all?
grind it so it has 2 parallel straight sides, put in vice an turn off
