Magura Oil
wardie
Hey, if you go into halfords and ask for LHM specialist mineral fluid, they should sort you out with it, its basically the same as magura royal blood. the tub that it comes in is black with green writing, also it comes in different sized tubs :)
I also have never seen anything bigger then 50 ml bottles. But, you could get hold of some DOT 4 fluid, its basically simular stuff but you can get it at any car shop or Spar and probably cheaper then maggie stuff.
Hey,
Its expensive dot 4/dot 5 brake fluid, also you cant put it in a magura brake (idealy)
Hope braking systems run on dot 4 or 5 brakefluid. it has a strong smell to it and would take the paint work of your bike, so beware :P
cheers
Edited by bllend
