Control-Trials Posted December 14, 2005 Report Share Posted December 14, 2005 Hi guys ive just had my wheel set from selectbikes its the old echo hubs with the built in chain tensioners and i have the zona zip frame and my wheel wont fit because the chain tenioners are too thick. Anybody else had this problem or has anybody got any help they could give me. Cheers !!!Dan !!! Quote Link to comment Share on other sites More sharing options...
mad dan Posted December 14, 2005 Report Share Posted December 14, 2005 Why dont you grind them down. Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted December 14, 2005 Report Share Posted December 14, 2005 Why dont you grind them down.Or ring Select Bikes to try and sort the problem rather than posting a topic straight away. I can see why your not happy but its not fair to Phil and the rest of the people at Select Bikes as it sort of looks like you are not happy with them and they have done something wrong. I am not having a go just saying that I dont think that you have gone the right way around doing things. Quote Link to comment Share on other sites More sharing options...
Deonn h Posted December 14, 2005 Report Share Posted December 14, 2005 1)You could either try strech you frame out slightly and pushing the hub in.2)Grind the tensioners down abit so the hub just slides in.3)Some how detach the tensioners from the hub.Hope this helps.ThanksDeonn. Quote Link to comment Share on other sites More sharing options...
totaltrials Posted December 14, 2005 Report Share Posted December 14, 2005 You can slide the tensioners off quite easilly, they do not effect the hub at all, if you do this you can replace the tensioners with spacers of some sort to get the correct spacing.Or:You can send the wheel back and we will refund you the price if it's not been used.Thanks.Phil. Quote Link to comment Share on other sites More sharing options...
Control-Trials Posted December 15, 2005 Author Report Share Posted December 15, 2005 Hi guys i am not having a go at anybody, i was just asking for a bit of advice on what i could do to sort the problem and i know its not phil's fault he is a great guy. Sorry if i opend the topic in the wrong manner.Cheers !!!Dan !!! Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted December 15, 2005 Report Share Posted December 15, 2005 OK Ill let you off this time hehe at least your sorted now Quote Link to comment Share on other sites More sharing options...
Barbra Posted December 15, 2005 Report Share Posted December 15, 2005 You can slide the tensioners off quite easilly, they do not effect the hub at all, if you do this you can replace the tensioners with spacers of some sort to get the correct spacing.Or:You can send the wheel back and we will refund you the price if it's not been used.Thanks.Phil.nice chap here Quote Link to comment Share on other sites More sharing options...
