Gears...and Tyres
Tom Booth
Alright lads/ladesses
Im soon to be running gears, And would like to know what sort of gearing is a decent set up....I saw hecasette on selectbikes and the 8 speed shifter....ut im a little put off as it is a 21-19-17 set up..would it be possible to loose the 21 and replace it and put an 18 in the adiquate place? Is the 8 speed shifter on there good? Or can someone recomend a decent rodie cassette which has an 18 tooth i and dosent go to high.
And my second question....What are the michelin comp 24's like for pinch protection? Im getting fed up of buying a maxxis every 3 months, and ive heard nothing but good about the michelin. just wondered about general info on these pleaaaase.
Cheers
Tom
What are the michelin comp 24's like for pinch protection? Cheers
Tom
the michelin comp 24s are very good for pinch protection. mine was very good and i had it for quite a while. the only problem is that after alot of bashing about, the metal beading in the sidewall pierced through the tyre and kept on giving me punctures <_< that was really anoying but i think its because i couldnt be arsed to get a new tyre and kept on running it down. other than that it was great (Y)
Tom
oh and i never got a pinch B)
Edited by T-Limburn
i bought a shimano HG-70 cassette in 21:12 then took it apart by unscrewing the three pins at the back of it, the highest gear that i use is 19 tooth as i use 22:19 ratio most the time i then ditched 2 of the gears think it was 21 and 14 and then replaced the two gears with three old metal cassette spacers
cassette works perfect and with first gear being spaced over a bit with the three spacers it gives you a great chain line
i use a modified xt 8 speed shifter pod, basically i unscrewed the screen that shows what gear you're in and then covered the top part in black duck tape to keep crap out, by taking it off you save a little weight and it has more space to rotate up a little bit more out the way. the actual thumb shifter part for changing into lower gears is quite large so i took a file and filed back the plastic alot making the thumb shifter much smaller and smoother shaped so it's alot more out the way, i finished it off with some sandpaper so it looks very smooth
ideal mech for this is a shimano 105 short cage, mine is also locked out so it doesn't bounce off the frame all the time, even though it's locked out all my gears work perfectly
The compo 24's are good but the 2.5 hot s is better! it just grips soooo much also only ever got 1 pinch on it runnin standard thickness tube, and they come with kevlar bead so loads lighter. i also run mine on a megamo rim at around 20psi and it has never ever come off. as long as you can handle the red colour :) ,
As for gears, go for a shimano roadie HG jobbie and see above, taking it apart and moving your prefered cog over with spacers and removing a couple of cogs is ideal.
i love michelling tyres!! My comp 24 is amazing! In terms of pinch protection, its very good! i've had a few... but thats my own fault with running the tyre presure farrr toooo low! They are very good tyres..... however i have noticed they tend to wear quite well - dunno how bad in comparison to other tyres (having only ever used a michellin!) but i got through 1 tyre riding every day for about 2 months..... So i spose its not all that bad.
Go for it! (Y)
your joking right ? :huh: i had more grip that time i ran an oil slick intead of a tire...
mike
Edited by leedstrials
mike
errrr........Nope, best tyre i've used by miles. and ive had a fair few. every IRC, some maxxis, Schwable, Tioga's, Echo etc and it far exceeds any of those. wouldn't swap it. However, i am liking the sound of these new Maxxis jobbies. anyone have one?? i dont have a clue what there called :blink:
Hmmm, I always found them awful. >_<
mike
I do believe they've had a compound change, so *maybe* they might work now?
only down side i would say is that they dont feel that nice to ride with, it gives a dead sorta feeling and no bounce unless you run stupidly low pressures.
i have to agree with rich here, as they are excellent tyres but seem to be almost a little too solid.
excellent tyres in terms of wear and pinch protection, but are a little dull on the back wheel with no bounce or real feel to them etc.
edit: oh and the 2.2 michelin is a very nice width when on a decent width rim. it is more like a 2.4 or something when on something like a koxx or echo rim.
infact the 2.5 version of the tyre when on a fat rim would probably be too wide. go for the 2.2 version.
Edited by T-Limburn
I've bought a shimano HG-70 cassette in 21:12....Gonna ditch the 21 and put the 19 in its place and put an 18 tooth where the 19 was :SLol..Anyway cheers for the help lads....Just need a shimano grip shift now..Lbs to the rescue..
I think the michelin will be bought when my maxxis dies (another month? 2?) So thanks again lads
Cheers
Tom
Only downside (depending on which way you look at it) with a Michelin is that the sidewall is so thick it feels 'dead' and much less bouncy than a Maxxis.
But i found i didn't of loads of lil correctional hops when i changed to a Michelin.
Thye last ages too.
My ideal set up would be Comp 24 2.2 rear, Try-all Stiky front.
  • 1 month later...
Where can i buy a 2.5 comp 24 for less than £35??
Is it possible?
Cheers,
Luke (Y)
Sorry it took me 4 weeks to reply to that but have a look on airevalley cycles, if i remember right they sell a 2.5 michelin comp 24 for £19.99 which is a lot less than £35.
yo...i changed from an el gato on a dx32 to a red (make any difference?) 2.5" hot s on a koxx rim...
and it is pretty shite in comparison really..grip wise..have to run it a fair bit harder too...
useable in the dry...but if it's wet, i nearly die (Y)
the 24 looks good...weighs a fair bit mind..
adam
