skye_trials Posted December 11, 2005 Report Share Posted December 11, 2005 Hi,I have a grind and i am only using standard magura pads, so i am wondering what pads would be the best.I was thinking about koxx blocks but i don't no which colour.any help would be very much appriciated.Cheers Allen Quote Link to comment Share on other sites More sharing options...
N.Wood Posted December 11, 2005 Report Share Posted December 11, 2005 It doesn't matter which colour, Browns will last the longest. Thay all have advantages.Plazmatic CRMs are good, and look at Heatsink and Coustellier too.You're new here so i won't go on about it, but this topic is very common and there are loads of posts if you give it a quick search Quote Link to comment Share on other sites More sharing options...
BeNNy Posted December 11, 2005 Report Share Posted December 11, 2005 yeah. im using koxx bloxx browns on a grind, and they work reallly well Quote Link to comment Share on other sites More sharing options...
skye_trials Posted December 11, 2005 Author Report Share Posted December 11, 2005 It doesn't matter which colour, Browns will last the longest. Thay all have advantages.Plazmatic CRMs are good, and look at Heatsink and Coustellier too.You're new here so i won't go on about it, but this topic is very common and there are loads of posts if you give it a quick search sorry mate!yeah. im using koxx bloxx browns on a grind, and they work reallly well Do they all work the same in water?Allen Quote Link to comment Share on other sites More sharing options...
MikeCottTrials Posted December 12, 2005 Report Share Posted December 12, 2005 i'd go for brown koxx bloxx Quote Link to comment Share on other sites More sharing options...
mat hudson Posted December 12, 2005 Report Share Posted December 12, 2005 koxx greys Quote Link to comment Share on other sites More sharing options...
anzo Posted December 12, 2005 Report Share Posted December 12, 2005 On the subject, I have a grind which is a few weeks old now and I cant really be bothered to take it off and freshen it up at the minute, so It's slightly smoothened itself out a bit now.However, I have some new pads on order and wont be here for a few days so I got some of the black standard maggy pads from Halfords, suprisingly, its a decent pad, however, it was a bit too soft and is now almost flattened after about 4 hours of riding.Im waiting until my rim is a bit more smoother and going back to kool stops with tar, it was sound on my bike. Squeeked like hell, locked on and there was no way that wheel would budge.Perfect example that changes aren't always the best option, I regret grinding my rim down. I'm sure there are plenty of people on here that will argue that a grind is the way to go and that kool stops are shitty, but it worked fine on my bike Quote Link to comment Share on other sites More sharing options...
Dan-Walker Posted December 12, 2005 Report Share Posted December 12, 2005 i have koxx bloxx reds and they are working well i have had them for about 3 months and they have only worn down about 2mm of pad, they have very good grip in the dry. They work very well in the wet aswell.when i need new pads i will get koxx bloxx reds again, i would reccomend them.Dan Quote Link to comment Share on other sites More sharing options...
mat hudson Posted December 12, 2005 Report Share Posted December 12, 2005 On the subject, I have a grind which is a few weeks old now and I cant really be bothered to take it off and freshen it up at the minute, so It's slightly smoothened itself out a bit now.However, I have some new pads on order and wont be here for a few days so I got some of the black standard maggy pads from Halfords, suprisingly, its a decent pad, however, it was a bit too soft and is now almost flattened after about 4 hours of riding.Im waiting until my rim is a bit more smoother and going back to kool stops with tar, it was sound on my bike. Squeeked like hell, locked on and there was no way that wheel would budge.Perfect example that changes aren't always the best option, I regret grinding my rim down. I'm sure there are plenty of people on here that will argue that a grind is the way to go and that kool stops are shitty, but it worked fine on my bike but your only 10-11 years old at max. heavier people put more pressure on their brake so grinds are v usefull. Quote Link to comment Share on other sites More sharing options...
skandy32 Posted December 12, 2005 Report Share Posted December 12, 2005 check out www.tartybikes.co.uk for a huge rang of pads.... they also explain which pads are good for different conditions and rims..... Heres the info about the koxx range.... (from the site)Koxx BloxxDescription: - The famous Koxx Bloxx are now availabe in more colours than ever before!- Browns remain the choice of a number of riders, outlasting pretty much all the pads on the market, while still retaining a very good level of performance in most conditions.- Red and Yellow were later introduced, which boast even better performance with slightly less impressive wear rate. These pads are designed mainly for dry conditions.- The Blue and Green compounds were developed to counter this, boasting excellent performance in the wet, at the slight detriment of wear and dry weather performance. A very consistent brake pad.- Assembled into brand new Power Pad backings to ensure safety and no clip life problems.Stock Information: Brown: In StockRed: In stockYellow: In stockGreen: In stockBlue: In stockPrice (inc. VAT): £18 (including 1st Class postage) Quote Link to comment Share on other sites More sharing options...
stevecoust Posted December 12, 2005 Report Share Posted December 12, 2005 Hi,I have a grind and i am only using standard magura pads, so i am wondering what pads would be the best.I was thinking about koxx blocks but i don't no which colour.any help would be very much appriciated.Cheers Allen in this cold wet weather i use the browns they work brilliant Quote Link to comment Share on other sites More sharing options...
anzo Posted December 12, 2005 Report Share Posted December 12, 2005 but your only 10-11 years old at max. heavier people put more pressure on their brake so grinds are v usefull.Error in my profile, I'm actually 17, 18 in March. Quote Link to comment Share on other sites More sharing options...
anzo Posted December 12, 2005 Report Share Posted December 12, 2005 just changing the pads wont neccesarliy make the brakes andy better..changing the levers and runnin a booster will help aswell... are we talkin front or rear wheel ??just changing the pads wont neccesarliy make the brakes andy better..changing the levers and runnin a booster will help aswell... are we talkin front or rear wheel ??anzo..u fancy a ride sometime?? i feel liek doing a natural ride in derby jus after crimboSure, I'm in Heanor, about 30 minutes bus trip to Derby. Drop me an e-mail. Quote Link to comment Share on other sites More sharing options...
Danny Swindlehurst Posted December 12, 2005 Report Share Posted December 12, 2005 for good brake prormance and quallity go for the plaz crm pads Quote Link to comment Share on other sites More sharing options...
deanie-b Posted December 12, 2005 Report Share Posted December 12, 2005 (edited) Plaz are great, I presume your running four bolt mounts??If you are I would consider getting a brake booster , I find Echo Controls are favourable, and perform well Also, Try bleeding your brake, there may be problems there.On another note! :Koolstops and tar is actually pretty good ! Edited December 12, 2005 by deanie-b Quote Link to comment Share on other sites More sharing options...
Hoot Posted December 12, 2005 Report Share Posted December 12, 2005 Get the plazmatics!! They are great pads, and would be a good match for your grind Quote Link to comment Share on other sites More sharing options...
deonn trials 55 Posted December 12, 2005 Report Share Posted December 12, 2005 I have nothing other to say than plazmatic pads.Best pads I have ever run , you won`t regret it. Quote Link to comment Share on other sites More sharing options...
Barbra Posted December 12, 2005 Report Share Posted December 12, 2005 for good brake prormance and quallity go for the plaz crm pads Quote Link to comment Share on other sites More sharing options...
watto Posted December 12, 2005 Report Share Posted December 12, 2005 or8 tolly its adam the lad with the onza t-raptor that hangs round with liam and foster and joe and everyone Quote Link to comment Share on other sites More sharing options...
skye_trials Posted December 12, 2005 Author Report Share Posted December 12, 2005 what wheel are we talkin here..front or rear??Rear wheel. Quote Link to comment Share on other sites More sharing options...
