Mission Prodigy Spec And Geo
smurftrial
It's all mission stuff apart from brakes which are some Vee's.
Resons not to get it:
Headtube 1.5 compared to normal 1 & 1/8. this makes t hard to update forks and stems.
Stem a dodgy clamp size makes it hard to updat bars.
14mm rear axles. wont fit in any other frames.
That means if you want a new frame you would need a new hub, new forks new stem and new bars.
new forks you would need new headset, new stem and new bars.
new wheel you would need a new frame, which means new forks bar and stem.
And its a waste of money compared with what you get ( a lump of shit)
Edit: Just read the question: The length is 1010mm on my mates, stays are 370mm
Weight: the frame itself isn't actually that heavy but everything else that comes with it is really heavy making it seem stupidly heavy.
Edited by Joe_Elding
Basically it's crap :P
be nice :P
It's not crap, It's just not good :-
The frame is actually light as joe said, But some of the parts on it are ridiculously heavy, Only the other day i stripped a mission down, to a bare frame, no forks or anything left on it, it was actually really light (Y)
Edited by deanie-b
ive already got one its just i wanted to know! Im gettin all the parts to change the frame to a zona! an im gettin aload of echo parts for it so it should be quite good Ie bb, forks , headset stem and later on when i have more money im gonna get a new pair of echo wheel builds!!!!
.....................................Smurf
