spanners Posted December 9, 2005 Report Share Posted December 9, 2005 hey......... wots the best way 2 put a headset in? Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted December 9, 2005 Report Share Posted December 9, 2005 hey......... wots the best way 2 put a headset in? Hi, most people use a vice to put one in with blocks of wood to stop damage to the cups, however i use the big pillar drill we have as a press and some people even use a block of wood and a hammer but i wouldnt advise that oh also make damn sure it goes in nice and straight or else it will flare your head tube Quote Link to comment Share on other sites More sharing options...
Synergy Posted December 9, 2005 Report Share Posted December 9, 2005 i would agee with sir trials alot, however my amtes and i have always sued a hammer and a block of wood, if you do it carefully it should be ok but if you still arent sure just go to a bike shop.let me know how you get on. Quote Link to comment Share on other sites More sharing options...
spanners Posted December 9, 2005 Author Report Share Posted December 9, 2005 How do you do it with a bit of wood an a hammer?sorry about this boys , Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted December 9, 2005 Report Share Posted December 9, 2005 How do you do it with a bit of wood an a hammer?sorry about this boys ,Get the bottom of the headstock of the frame on something solid and warm the frame headstock with boiling water to expand it a little bit (to make the headset easier to press in) and place a little grease on the top cup where it goes into the frame. Next place the top cup in its desired place and push it in as much as you can with your fingers. Then get your piece of wood that covers the full area of the cup and hit it on top of the cup. Keep checking that the cup is going in straight on the way down, just take your time. Warm the frame again and repeat all those steps for the bottom cup. Like i say just take your time and be patient. If a cup does tip over a little bit get a smaller bit of wood that can cover the bit that is sitting higher and tap it GENTLY untill it sits straight and then carry on tapping it down with the larger piece of wood. NEVER use a large hammer, just use a medium one so your not forcing/hitting the cup too hard. If there's anything else you need to know just drop me a line and ill do my best to help Quote Link to comment Share on other sites More sharing options...
Trials Dave Posted December 9, 2005 Report Share Posted December 9, 2005 use a bench vice. thats what ive always done. its really easy and it goesa in nice and straight. i think its the easiest way by far. cant go wrong. Quote Link to comment Share on other sites More sharing options...
andypro1 Posted December 9, 2005 Report Share Posted December 9, 2005 i made my own headset tool i got a peice of threaded bar and pur two peices of flat steel on it then two nuts.then all you do is tighten the nuts and it pushes the cups in so a bit like using a vice Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted December 9, 2005 Report Share Posted December 9, 2005 I found using my pillar drill as a press was the easiest but not many people will have one and not everyone on here has a vice. By the sounds of things he hasnt got either because he was asking about the block of wood and hammer technique. Oh well, opinions, opinions Quote Link to comment Share on other sites More sharing options...
spanners Posted December 9, 2005 Author Report Share Posted December 9, 2005 Thanks a lot amigos my headset is know in place.................... thanks agen Nommie Quote Link to comment Share on other sites More sharing options...
Synergy Posted December 9, 2005 Report Share Posted December 9, 2005 good to hear Quote Link to comment Share on other sites More sharing options...
am4zin Posted December 9, 2005 Report Share Posted December 9, 2005 so you can use a block of wood and a hammer to get the cups in, but then how would you go about taking the cups out? Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted December 9, 2005 Report Share Posted December 9, 2005 so you can use a block of wood and a hammer to get the cups in, but then how would you go about taking the cups out?the popular one for that is a large screw driver and a hammer but some people cut a piece of metal so theres 4 bits on the end and pull them out. you then pull it through your headtube and when it springs in behind the headset cup you can hit your cup out with the metal Quote Link to comment Share on other sites More sharing options...
BASETA26ER Posted December 9, 2005 Report Share Posted December 9, 2005 there's two way the neat and tidy way is to get abit of threaded bar with a nut on one end then a rather big washer what will fit over the bearing cup's then the opposite on the other side then tighten the nuts so that then it will pust the bearing cups in to the frame, it takes a wile but it costs basically nothing and it doesn't scratch anything/ damage anything but then again theres the other way which people have been saying hammer and a bit of wood, does the job but not the best of ways.. hope ive helped.. marc Quote Link to comment Share on other sites More sharing options...
MrsMonkey Posted December 9, 2005 Report Share Posted December 9, 2005 there's two way the neat and tidy way is to I CAN'T READ get abit of threaded bar with a nut on one end then a rather big washer I OBVIOUSLY DIDN'T READ THE TOPIC what will fit over the bearing cup's then the opposite on the other side then tighten the nuts so that then it will pust the IN MY SAD ATTEMPT TO LOOK HELPFUL AND INCREASE MY POST COUNT IN ORDER TO DRAG MYSELF OUT OF NEW MEMBERS CHAT I HAVE ONLY SERVED TO MAKE MYSELF LOOK COMPLETELY RETARDED AND PROBABLY HINDER MY PROMOTION bearing cups in to the frame, it takes a wile but it costs basically nothing and it doesn't scratch anything/ damage anything but then again theres the other way which people have been saying hammer and a bit of wood, does the job but not the best of ways.. hope ive helped.. marcIt's got to be said. There's a million topics on here every day which get dragged up repeatedly when they're well past their sell by date. Guy's READ THE TOPIC, you'll save yourself from looking like a complete ass and polluting the forum with unnecessary repetition. Quote Link to comment Share on other sites More sharing options...
BASETA26ER Posted December 10, 2005 Report Share Posted December 10, 2005 It's got to be said. There's a million topics on here every day which get dragged up repeatedly when they're well past their sell by date. Guy's READ THE TOPIC, you'll save yourself from looking like a complete ass and polluting the forum with unnecessary repetition.well who's dragged the topic up now, sill bi*ch Quote Link to comment Share on other sites More sharing options...
