Hows Everybody Finding High Rise Bb Frames?
Mr_Pitbull
I ride an 06 Pitbull and am finding the process of getting used to it dragging on abit. Yes gaps are nice but Taps are just awkwerd, sidehops are fine :$
Anybody really getting along with there High BB frame? If so specify what frame you ride please ;).
Edited by Mr_Pitbull
ok this is my view, ive riddin a vinco and its very nice on the backwheel, but i really cant gap for sh*t on it, ive riddin a adamant a1 withfattys so it brings the bb rise down a bit from 55 to 35mm i think and i prefer that to the vinco, and in a couple of weeks i will be riding my mates new limey with hi fi forks so i think it will bring the bb rise up to about 25mm instead of the standard 15mm and i cant wait.
personally i think if you just role over stuff without any effort then yes get a koxx vinco :$ but i say that this frame has way too much bb rise
the adamant and czar frames have it perfect in my view, just enough bb rise so its easier on the backwheel and wheelswaps etc
hope this helps mate
cheers ric
and if anyone disagrees fine this is my opinion here and im sticking to it ;)
cheers ric
I Don't want a Vinco, 80MM BB rise is crazy. I have seen TRA ride his Vinco and he also and I quote " Best frame i have ever ridden so far" so it must be suiting to his style some way.
ok yes the vinco is extreme with bb rise but the pitbull has a 55mm bb rise or 50 and the czar and adamant has less than that i believe il check in a min
my bad
czar- 60mm
a1- 55mm
a2- 55mm
pitbull- 50mm
all the frames still lovely to look at :$
my bad
czar- 60mm
a1- 55mm
a2- 55mm
pitbull- 50mm
55mm, 1085 length mine aswell.
Edit: Also im guessing your lanky, so perhaps the Vinco might be suited to your hight better.
I have an A1 and I can gap further, sidehop higher, and hook higher.
Taps are the only hard thing...watch vincent. He has +40mm and he does taps to front, then switch to rear. It really works!
It just takes time to get used to...a month to get taps dialed. Everything else I could do in a day though.
