Magura Help
trialsinchris
hi i recently bought a rear hs33 for my bike and fitted it ok i thought, but when finished i found i had the quick release sat on the side and had no idea how to fit it so can anyone tell me how. by the way the brake booster i got dont fit over tyre so if i need that to fit quick release please tell me. thanks.
Hey, do you ride mod or stock? If its mod you mostly have to buy aftermarket boosters, like the viz, onza, echo etc ones! Also with mods as far as i know they all use 4 bolt mounts, and if you running quick release i assume your running the evo clamps for the brakes, if you are it best to swap to the four bolt clamps, most of the trials shops on the net stock them, once youve got a set of those on fittings a breeze, hope it helps!
get 4 bolt mounts if you have them :P
What good will that be?
If he has 'V' mounts on his frame, he needs the Evo miunts for the magura.
You don't really need the quick release part, they're optional.
As long as it's all on and working, it'll be fine without it :P
