Which Chain Tensioners For My Zoo
sammerz
Hey, I have a Zoo! Python and was wondering 'what chain tensioners can I run on it?'
I have Echo snail cams at the moment and they aint that good because my profile is big enough and it is really tight with the wheel and snail cams in at the same time. I can't run the snail cams on the outside of the frame because there is CNCing in the way!!!!
Any suggestions? :lol:
Sam
Yet again the lovely peopleof the forum give helpful advice! I had this problem for the week or so I had the python :huh: I triedsnail cams and some giro ones but neither fittet. The standard T-pro (onza) chain tugs are too big aswell. So if you wanted do what I did and cut them down. Get a hack saw and cut straight across the top or bottom then they fit fine! ......... but look cheap and nasty >_<
Josh..
  prawn said:
for christs sake sort your life out and give the thread a proper title!
how about
'chain tensioners for a Zoo python'
my zoo? whats that mean? have you got a collection of f**king animals?
You could join my Zoo then with a name like 'Prawn' :huh:
Sam
Edited by sammerz
  MOSH said:
Yet again the lovely peopleof the forum give helpful advice! I had this problem for the week or so I had the python :) I triedsnail cams and some giro ones but neither fittet. The standard T-pro (onza) chain tugs are too big aswell. So if you wanted do what I did and cut them down. Get a hack saw and cut straight across the top or bottom then they fit fine! ......... but look cheap and nasty :huh:
Josh..
it was your king that caused the problem with the snailcams not fitting though wasnt it josh B)
and you talk of people giving helpfull info (Y)
only jokin moit ;)
