Swize Posted December 3, 2005 Report Share Posted December 3, 2005 (edited) Out riding my bike and my profile screwed up :S . So i need to no how to get inside of it to check it all out. Ive got the big spanner but what else do i need a chain whip of something ? Also just to give me a clue with what could of broken the hub what is the most commen thing to go wrong ? Cheers Sam Edited December 3, 2005 by samthebiker Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted December 3, 2005 Report Share Posted December 3, 2005 you haven't even told us what went wrong with it, so how are we meant to tell you the cause? i presume you need to get to the ratchet ring and pawls? if so, take the hub out of the frame and simply pull the driver off with your hands. sont bother with chainwhip or large spanner as thats for mounting the cog only. hope this helps Quote Link to comment Share on other sites More sharing options...
Swize Posted December 3, 2005 Author Report Share Posted December 3, 2005 (edited) you haven't even told us what went wrong with it, so how are we meant to tell you the cause? i presume you need to get to the ratchet ring and pawls? if so, take the hub out of the frame and simply pull the driver off with your hands. sont bother with chainwhip or large spanner as thats for mounting the cog only. hope this helps I just asked what was the most common problem. But cheers for the help the problem was i did an up and it was fine jumped back and went to role along and the hub was reall unsmooth like there was a pawl sticking or something also you could move the cranks backwards and insted of freewheeling it would spin the wheel thats the best i can explaine really :S . Cheers Sam Just grabed a pic everything seams to look fine, but note the scratch at about 4 0'clock could this mean a pawl had fallen out of place ? How can i tell if the earings have gone? Edit : Edited December 3, 2005 by samthebiker Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted December 3, 2005 Report Share Posted December 3, 2005 They'll feel loose and shit if they went. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted December 3, 2005 Report Share Posted December 3, 2005 it'll [probarbly be a bit of metal (from the ratchet) that has snapped off(only a shaving). all you need to do is clean it all out and then wack it back together. btw, this happened to mine once and also one of my mates ones. nowt to worry about :S Quote Link to comment Share on other sites More sharing options...
Bionic Balls Posted December 3, 2005 Report Share Posted December 3, 2005 and perhaps would happen everytime you pedal if using a bulb hub. adam.. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted December 3, 2005 Report Share Posted December 3, 2005 and perhaps would happen everytime you pedal if using a bulb hub. adam.. hehe quite true :S Quote Link to comment Share on other sites More sharing options...
Swize Posted December 3, 2005 Author Report Share Posted December 3, 2005 it'll [probarbly be a bit of metal (from the ratchet) that has snapped off(only a shaving). all you need to do is clean it all out and then wack it back together. btw, this happened to mine once and also one of my mates ones. nowt to worry about :) Awsome cheers will all sorted now it was exactualy that :S Sam Quote Link to comment Share on other sites More sharing options...
